Old 02-12-2013, 12:53 PM   #1
rpicard@demand-its.com
Drives: 2007 Yaris Hatch
Weird Noise, unsure
I have a 07 yaris with 180,000km on it.
Theres a odd problem I've had for a while now but we can't figure out where it comes from.
When driving, at around 2500rpm with gas there is a noise that we can best describe as sucking milk through a straw when the cup is almost empty.
If I take my foot off the accelerator at 2500rpm the noise goes away, if I go up to 2800 rpm I can't hear it anymore.
I tend to only notice the noise in the third and fourth gears.
It may be nothing, it may be something but I have no idea what to look at.
rpicard@demand-its.com is offline   Reply With Quote
Old 02-12-2013, 01:53 PM   #2
CoryM
Drives: 2009 5-door, 5-speed
Check your coolant level. If there is air in the system it can make those noises as it passes through the heater-core (in dash). Often loudest when cold and you first bring the engine rpm up. You can also get odd noises from the airbox/intake, but they are normal. Can't hear it on most cars, but you can on the Yaris.
Cheers.
Old 02-12-2013, 03:52 PM   #3
TOLMACH
Drives: soarer
that is normal for this engine.. everybody hears this sound (some people just do not pay attention).. i think it is caused by the intake / throttle body design
Weird Spark Noise Behind Steerinf Column! ChitownY@Ris DIY / Maintenance / Service 8 07-28-2011 11:18 PM
Weird noise upon turning hazzy DIY / Maintenance / Service 3 07-08-2011 07:07 PM
The weird, old and new. Brakes, Sqeaking, Suspension noise Lafiro DIY / Maintenance / Service 2 10-31-2010 10:20 PM
weird rattle-grind noise when braking. krolos General Yaris / Vitz Discussion 4 08-10-2010 07:07 PM
07 yaris weird engine noise mr07yaris General Yaris / Vitz Discussion 22 07-21-2010 08:33 AM
