Drives: 2007 Yaris Hatch Join Date: Jul 2012
Weird Noise, unsure
I have a 07 yaris with 180,000km on it.
Theres a odd problem I've had for a while now but we can't figure out where it comes from. When driving, at around 2500rpm with gas there is a noise that we can best describe as sucking milk through a straw when the cup is almost empty. If I take my foot off the accelerator at 2500rpm the noise goes away, if I go up to 2800 rpm I can't hear it anymore. I tend to only notice the noise in the third and fourth gears. It may be nothing, it may be something but I have no idea what to look at. |
Check your coolant level. If there is air in the system it can make those noises as it passes through the heater-core (in dash). Often loudest when cold and you first bring the engine rpm up. You can also get odd noises from the airbox/intake, but they are normal. Can't hear it on most cars, but you can on the Yaris.
Cheers. |
#3 | |
![]() ![]() ![]() ![]() Drives: soarer Join Date: Feb 2011
| Weird Spark Noise Behind Steerinf Column! | ChitownY@Ris | DIY / Maintenance / Service | 8 | 07-28-2011 11:18 PM |
| Weird noise upon turning | hazzy | DIY / Maintenance / Service | 3 | 07-08-2011 07:07 PM |
| The weird, old and new. Brakes, Sqeaking, Suspension noise | Lafiro | DIY / Maintenance / Service | 2 | 10-31-2010 10:20 PM |
| weird rattle-grind noise when braking. | krolos | General Yaris / Vitz Discussion | 4 | 08-10-2010 07:07 PM |
| 07 yaris weird engine noise | mr07yaris | General Yaris / Vitz Discussion | 22 | 07-21-2010 08:33 AM |
