Old 07-14-2007, 08:29 PM   #1
KSIbucky
KSIbucky's Avatar
Drives: 2007 Yaris manual dark silver
Send a message via AIM to KSIbucky Send a message via MSN to KSIbucky
12v plug thingy
i was wondering what wire to use from the plug the gray or the black and white one thanx
edit: also does anyone know how to take the plug out
7 Color Tach
Fujita Intake
Momo pedals Shift knob and boot. Full TRD SSK.
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
KSIbucky is offline   Reply With Quote
Old 07-14-2007, 09:04 PM   #2
flighttekchris
flighttekchris's Avatar
Drives: 2007 Yaris 3door
i think you are asking what wire is the positive and what is the negative.. right?? the wire on the center pin is positive the other is the ground
flighttekchris is offline   Reply With Quote
Old 07-14-2007, 11:29 PM   #3
KSIbucky
KSIbucky's Avatar
ya i'm wondering what one is postive do you know what color the wire is otherwise i can figure it out
7 Color Tach
Fujita Intake
Blitz exhaust
(Next is DC Header)
Old 07-15-2007, 07:19 AM   #4
flighttekchris
i think the positive wire is gray check the Electrical Wiring Diagram Manual page 220, hope that helps,
chris
wichita ks
Old 07-15-2007, 07:50 AM   #5
Edd
Drives: None
You could just use a multimeter. Or for a ghetto check, just put an LED in, as it will only light up when it's the right way around (although it will overheat and blow quickly without a resistor with it). Remember on an LED, flat side = negative and long wire = positive.
Edd is offline   Reply With Quote
Good place to find constant & switched 12V behind dash? atebit In Car Entertainment + Electronics (audio / video / alarm) 16 03-03-2009 10:40 AM
Toyota AUX plug w/ aftermarket radio? eight_heads In Car Entertainment + Electronics (audio / video / alarm) 20 09-07-2007 02:41 AM
DIY: 700w Power Inverter & additional 12v aux. plug w/pics Astroman DIY / Maintenance / Service 6 08-08-2007 01:05 PM
DIY: Discreet Mounting of 12V adaptor for the Gtech & V1 H8SGAS DIY / Maintenance / Service 7 09-26-2006 02:50 AM
Harman Kardon Drive + Play for IPOD sroberts In Car Entertainment + Electronics (audio / video / alarm) 5 07-01-2006 01:05 PM
