![]() Drives: 2007 Yaris 3door Join Date: Apr 2007
17X7 wheels
ok I'm confused, i am looking at a set of Urban Racing 17X7 Type 8 wheels, with 205-40-17 tires, will this fit my LB without rubbing? can anyone help me with this? |
Yup, that's what I have. Just sure the bolt pattern is 4x100 and the offset is anywhere from 38mm to 45mm (40-42mm is best).
![]() Drives: Yaris E A/T 2007 Join Date: Jul 2007
I think it will not rub.. do not more than +38 offset
der Zeck
as peter said 40-42 is the best +45 in the front and +38 in the back would be pretty phat with 205/40's all the way around
#5 | |
Depending on the tire, ET38 may poke out a bit up front, ET40-42 would be much better, and ET45 would give you a tiny tuck up front which usually looks best and eliminates most rubbing problems. If you're not lowered, go with 205/45's. If you're lowered, you may want to go with 205/40's, especially if you run ET38's. However, you could manage 205/45's if you're lowered and you have chosen the proper offset. |
#6 | |
PetersRedYaris can you post some pictures of you tires so i can see how they fit? what offset do you have? BTY i am new to this.... what is "offset" anyway? thanks chris
der Zeck
Damn you EchoHrs Damn you... stop posting that incredibly hot ass picture of your ride...... I think the US needs to invade Canada so we can aquire the 5DR RS Yaris... why not? We invaded Iraq for WMD that were not even there, at least we would get the RS out of Canada :)
Look here-
http://www.yarisworld.com/forums/fun...do=view&id=153 I have Tanabe NF210 springs for a drop of 1.1 in the front and 1.3 in the rear. My tires are 205/40/17 and wheels are 17x7 with 38mm offset. Remember, the lower the offset, the furthur OUT it places your wheels. So, I am as wide as is recommended (as seen in the close-up of the front wheel). I have never rubbed, probably due to the slightly smaller tire diameter. Good luck. |
Does anyone know the stock wheels offset? I looked at rims and asked what the offset is and they said factory......
#10 | |
Passin' The Gas...Station
That's quite the lunch box you have there up on your roof. How's the ride with that thing? I'm assuming there is wind noise but any vibrations or the like? Looks good and thanks for the all info. Just because WE all don't ask the questions doesn't mean WE all can't learn from YOUR answer.
MY Gas Station Attendant Misses Me...![]() Chuck |
| When will the Yaris hit the showrooms at dealers? | Petrolhead | New YARIS Purchase Forum | 181 | 11-28-2011 08:03 AM |
| Feedback on these wheels | BulletProofAuto | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 21 | 06-04-2007 09:09 PM |
| Buddy Club Wheels | BulletProofAuto | Sponsors Classifieds Area | 8 | 10-19-2006 07:55 PM |
| Do bigger wheels and tires improve performance | Driver | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 14 | 10-14-2006 07:01 PM |
| Enkei RZ5 wheels on Liftback | kennywhy | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 09-23-2006 05:22 AM |
