Old 05-10-2021, 11:48 AM   #1
esse10
Drives: 2009 yaris 2 door
water pump lifespan
hello, anyone know what's the average lifespan of the water pump in these cars? I have a 2009 with 259k miles and still have the original water pump. I have no issues at this time but feel like it's about the go out on me soon and don't want to be stranded. what is everyone's experience on water pump failures? do they start leaking from the wheep hole before they completely fail or what? any noises before they fail? Should i just be pro-active and replace it before it fails on me? Any torque specs on the water pump screws would be helpful also, thanks guys.......
esse10 is offline   Reply With Quote
Old 05-10-2021, 02:50 PM   #2
KALISPEL II
KALISPEL II's Avatar
Drives: '26 Mazda 3 Select-Sport Sedan
Yaris water pumps have been known for their premature failure rates, so count your lucky stars that yours made it to 259K, let alone only 75-100K.
2026 2.5L NA Mazda3 Select-Sport Sedan 6-AT FWD (w/Chrome-Delete) - Soul Red Crystal Metallic - Built in Japan
KALISPEL II is offline   Reply With Quote
Old 05-10-2021, 02:59 PM   #3
15yrs, 375,000km and still on the original. It seems to be a hit or miss component. I do believe that the reports of failure dropped 2009+.
Old 05-10-2021, 03:04 PM   #4
bronsin
bronsin's Avatar
Hi leave alone. My 2009 went out at 25,000 miles.
The clutch, fuel pump, alternator, carburetor and distributor on my 1974 beetle went 250,000 miles.
The wife’s Camry 2005 Has had two water pumps in 190,000 miles
Old 05-10-2021, 03:24 PM   #5
Leegamer
Leegamer's Avatar
I got about 130k out of mine
I'm a hermit named Lee
Old 05-10-2021, 03:53 PM   #6
esse10
water pump
Okay , thanks guys
Old 05-11-2021, 09:10 AM   #7
esse10
weep hole
So it's best to just leave it until it starts leaking out of the weep hole ? You don't think it'll lock up on me and ruin the belt and leave me stranded?
Old 05-11-2021, 09:19 AM   #8
First sign of failure is usually the appearance of coolant being sprayed in a line on the underside of the hood. I'd just leave it be and look for signs of spraying everytime you have the hood open. While there have been a lot of failures, there are also plenty that have not experienced issues. No point throwing money at something out of paranoia.
Old 05-11-2021, 10:07 AM   #9
bronsin
bronsin's Avatar
No mine lead for 5000 miles before I had it fixed. As we Jari says check the bottom of your hood regularly for pink Koolant Stains.
Good luck!
Stains.
Good luck!
Old 05-12-2021, 04:25 PM   #10
esse10
water pump
it's not paranoia, it's just that i commute a long ways to and from work everyday and would hate to be stranded 65 miles away from home then it'll cost more money just to get it home. Okay y'all are the expert here i'll leave alone and keep an eye out for coolant leaks especially around the weep hole and let's see how many miles it'll make. As long as it starts leaking before a catastrophic failure i'm okay with that and then i'll know to replace it.
Old 05-13-2021, 10:06 AM   #11
bronsin
bronsin's Avatar
Like I said, I had the pink line on the bottom of my hood for 5000 miles before I had the pump fixed under warranty. Water pumps used to fail a week or two after the first league but that was 30 years ago. These Toyota pumps are different. If you have a good one, keep it!
Old 05-13-2021, 10:24 AM   #12
tmontague
tmontague's Avatar
As others stated, they rarely will just fail catastrophically but rather leak.
I had a cheap aftermarket one start failing 12 months after it was installed. The bearing started to fail but the warning was a terrible noise. Your water pump wont go from being quiet and working fine to put of no where completely seizing.
As long as your coolant was replaced at proper intervals to keep the wp lubricated, you will be fine.
Old 05-13-2021, 04:58 PM   #13
xdarkxfirex
Drives: 2015 yaris le
I replaced mine on my 08 Yaris back in 2015 when it had around 140km. I used an airtex water pump and it worked fine when I sold it 3 years later
xdarkxfirex is offline   Reply With Quote
Old 06-04-2025, 08:25 AM   #14
esse10
UPDATE ON THIS TOPIC; My car 2009 with 375k miles is doing good so far and no leaks from the WATER PUMP. jUST Wanted to update you fellas out here how long this water pump has lasted. i have a new pump sitting in my garage collecting dust ready for install LOL
Old 06-04-2025, 06:55 PM   #15
ex-x-fire
I treated mine like a timing belt. I did it at 100k. Old one was fine. I installed an Asin. I put the old one with the spare tire.
Old 04-13-2026, 12:57 PM   #16
esse10
UPDATE; My car (2009) is at 395k miles and still have the original water pump. Just wanted to update yall here and see who else has high mileage on their yaris. It uses about 1/2 quart of oil every oil change interval of 5k miles.
Fuel pump upgrade... Neinris Performance Modifications 31 12-16-2024 03:27 PM
Changing the water pump on a TS 06YarisRS Yaris TS Talk 3 10-05-2020 05:50 PM
2007 - Water pump suggestions littleblackyaris DIY / Maintenance / Service 1 10-04-2020 08:51 AM
Odd Fuel pump issue. Feeling at a loss. Marchalis DIY / Maintenance / Service 4 03-06-2018 08:55 PM
Location of Water Pump lululovesu DIY / Maintenance / Service 1 10-19-2014 08:05 AM
