Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Technical Forums > Yaris TS Talk
Old 10-05-2020, 05:54 AM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Changing the water pump on a TS
Just wondering about the configuration of the TS engine bay. Is there room between the engine and the subframe for removing the water pump? Since my 2ZR engine swap, it looks like I'd have some trouble getting the water pump out. I haven't measured, but I bet there isn't much more than an inch - if that - between the water pump pulley and the frame rail. This is for future reference only as I don't have any issues with the pump at this time. Thanks in advance.
2007 - Water pump suggestions littleblackyaris DIY / Maintenance / Service 1 10-04-2020 08:51 AM
Why the water pump went on my 2009 a theory bronsin General Yaris / Vitz Discussion 19 08-06-2018 12:45 PM
Odd Fuel pump issue. Feeling at a loss. Marchalis DIY / Maintenance / Service 4 03-06-2018 08:55 PM
Location of Water Pump lululovesu DIY / Maintenance / Service 1 10-19-2014 08:05 AM
HELP: changing water pump dlplunkett44 DIY / Maintenance / Service 4 02-06-2011 09:26 AM
