Janghwa, Hongryeon
Drives: 20th AE VW GTI Join Date: Aug 2007
Lightweight batteries anyone?
Anybody have a lightweight battery in their Yaris?
I figure a lightweight drycell in the trunk will help out a bit with weight distribution/reduction quite nicely.
22B | 藤原とうふ店 | Fatal Frame | 呪怨 | 장화,홍련 | Strong Bad
How to survive a Zombie attack "The inerasable scars, left by the palms of my hands" 365tuners |
Modded Moderator
I've wanted to get one for track days.
Janghwa, Hongryeon
I figure the motor being a 1.5 shouldn't require mountains of juice to turn over.
Braille's All-season joint (15lbs) should take a fair amount of weight off the car, and putting it in the trunk should help balance things out a bit. Just wanted to see if anyone had first hand experience with them in the Yaris. Noticable change? How much did the stock battery weigh? Any problems starting?
Deka (aka Braile) from Helix13. Though in the stock mounting position.
Hi!
03Z33 has an odyssey in the stock location. i think he saved about 20 lbs. i was going to do a relocation but the added weight of 1/0 cable, distribution block, battery mount, etc, would counteract the weight loss of a lightweight battery.
i think a race battery in the stock location is the best solution. |
Janghwa, Hongryeon
I see your point.
Still, moving a large mass to the rear, and alleviating the front end altogether doesn't seem like a bad proposition.
#7 | |
Hi!
if it is weight savings you want, then just replacing the battery with a race battery is the way to go imo. |
#8 | |
Janghwa, Hongryeon
I'm all for adding lightness, and balance in whatever quantities I can. If that means removing 30lbs from the front of the car, adding 15lbs to the back, and maybe 1-2lbs over the length of the car, that works for me ;) Factoring in the weight of the cables is glaringly good point I never thought of in nearly 7 years of modding cars
Hi!
if you use 1/0 welding cable as your power line, 10 feet of it is going to weigh more than two lbs i think. but if you do the relocation, post pics! i did one in my prerunner but opted not to in the yaris. good luck!
![]() ![]() ![]() ![]() ![]() Drives: LB-Auto-PWR-ABS-Cruise-Springs Join Date: Aug 2006
What do y'all think about Optima batteries. They claim to be light weight.
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime Get YarAss in gear! RIP - Casey Tatum |
Janghwa, Hongryeon
I always though Optimas were basically just spillproof.
Didn't think they had specific ranges of light batteries
#12 | |
46 and 2, just ahead...
Drives: 07 Yaris sedan Join Date: Jun 2007
I suppose we could just get a hand-crank like in the roaring 20's
Janghwa, Hongryeon
^ Theres an idea :D
Janghwa, Hongryeon
Might come up short in the CCA department. Nevertheless that'll knock some weight off :D
11b1p
does any think a goldwing battery would work. The engines bigger but battery must be smaller.
oh hell i actually clicked on that... doh!
| lightweight flywheel from fidanza | dngz | Performance Modifications | 34 | 02-04-2009 12:02 AM |
| dual batteries or use a cap? | punch | In Car Entertainment + Electronics (audio / video / alarm) | 14 | 07-17-2007 04:19 AM |
| anyone know the benifits of lightweight wheels? | BrazdonW | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 59 | 07-16-2007 09:22 PM |
| ZPI Racing Toyota Yaris 06-07 Lightweight Crank Pulley | SebYRS | Items for Sale by private party | 7 | 06-19-2007 09:00 PM |
| Toyota plans hybrid that runs on batteries | hhcchen | Off-topic / Other Cars / Everything else Discussions | 2 | 07-22-2006 02:35 AM |
