Old 01-15-2007, 08:03 PM   #1
dngz
dngz's Avatar
Drives: black yaris sedan
lightweight flywheel from fidanza
Just got an email back that Fidanza has a lightweight flywheel for the 2007 Yaris 1.5 DOHC. The part number is 133151. Just waiting back for pricing and info!
dngz is offline   Reply With Quote
Old 01-16-2007, 07:03 AM   #2
Chris07LB
Chris07LB's Avatar
Drives: Yaris Liftback
Had one on my 330 BMW. Made quite the difference.
Old 01-16-2007, 11:07 AM   #3
acrbill
Drives: Polar White Hatch
The Fidanza site says the flywheel weighs 8 lbs.
Here is one on ebay.
http://cgi.ebay.com/ebaymotors/FIDAN...spagenameZWDVW
Doing some searching shows that the stocker weighs 15lbs.
Old 01-16-2007, 12:21 PM   #4
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
If you do the flywheel, you have to do the clutch. And you have to do a DYI.
I would love to do mine but it's going to have to wait until later in the year.
Galavoxx is offline   Reply With Quote
Old 01-16-2007, 12:33 PM   #5
St_G
Drives: Black 2007 Yaris Liftback 1.5
I get nervous about mods in the powertrain that aren't TRD; it just seems like it would be too easy for warranty work to be denied.
St_G is offline   Reply With Quote
Old 01-16-2007, 01:16 PM   #6
acrbill
That is very true. If you have warranty work done on the engine or trans and they discover an aftermarket flywheel there is a good chance they will deny coverage.
This is probably not a mod for the bolt on mod crowd.
Old 01-16-2007, 01:47 PM   #7
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
What are the pros and cons of this mod in a small engine like the Yar?
A BMW 330 is not a good reference...
Old 01-16-2007, 02:46 PM   #8
Chris07LB
Chris07LB's Avatar
Wasnt making a reference to the Yaris... I was stating I had one in my 330, and it made a difference. Read.
Old 01-16-2007, 06:14 PM   #9
dngz
dngz's Avatar
you think a $800 CAD Tom's lightweight flywheel will be under warranty?
Old 01-16-2007, 06:51 PM   #10
ChinoCharles
Drives: LB
A good way to check would be to call the dealer and see if they'll install it.
Old 01-17-2007, 10:16 PM   #11
gr8yaris
gr8yaris's Avatar
Drives: 07 Yaris Hatchback
Less "rotational mass", more horepower goes thru to the wheels. There is also faster clutch engagement during shifting. I replaced the stock 15 lb flywheel in my JDM powered 1.3 L turbo Tercel with 8 lb JUN flywheel and it was a huge improvement in acceleration.
Toyota Yaris............1.5L NA.......2300 lbs....... HP=105+
Toyota JDM Tercel....1.3L Turbo...2100 lbs....... HP=160+
2007 White Liftback 5-speed
Tanabe DF 2" lowering springs, 205/50-15 on 15x6.5 Konig Helium, TRD rear sway bar, 15mm Hub spacer
http://picasaweb.google.com/USAntonio/MyGarage#
gr8yaris is offline   Reply With Quote
Old 01-18-2007, 02:40 AM   #12
graywolf_14
Drives: um not a yaris but hopefully
Or if it looks basicly like a stock one dont say a dang thing.
graywolf_14 is offline   Reply With Quote
Old 01-18-2007, 09:32 AM   #13
Chris07LB
Chris07LB's Avatar
Old 01-18-2007, 01:01 PM   #14
boris13
Drives: 2007 Yaris Liftback, 5-speed
Will a lighter flywheel decrease torque?
boris13 is offline   Reply With Quote
Old 01-18-2007, 01:05 PM   #15
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
No.
Old 01-18-2007, 01:16 PM   #16
CASTREX
CASTREX's Avatar
But on the down side, I've heard that revs will also drop faster... is this right?
Old 01-18-2007, 01:43 PM   #17
Galavoxx
Galavoxx's Avatar
Drives: Yaris Hatch
If you were to sit with the car in neutral or with the clutch depressed and rev the engine, yes, the revs will decrease more quickly from high rpms. This is because the lighter flywheel stores less energy. It takes less energy to rev it up and it take less time to dissipate that energy. On the upside, engine breaking is greatly increased as is the engine's ability to rev faster. The car will slow more quickly on downshifts without using the brakes. Some peolpe like this, some do not. This is another reason why this mod is not a bolt on and is not for a person looking for "driveability" in the car. Depending on how light the flywheel is made, it can make the car very unconfortable to drive. Throttle can be very revvy, some say twitchy. Of course, on a car with only 100 or so horsepower, it probably wont be that severe.
Old 01-18-2007, 01:49 PM   #18
ChinoCharles
Drives: LB
Sounds like fun. I engine brake a lot too. Its like a game... "See how far you can drive without using your brakes!"
