![]() ![]() ![]() Drives: Scion FRS Join Date: Aug 2006
Problem with Projector Halo :(
Well I bought my projector(the depoautolight one) off of an ebay store, everything went great except only 3 out of 4 halo's work... my right front halo doesn't work =(
So I was wondering is it possible to just cut the wire connecting to the front left one so it'll look even, or will that completely drop the 2nd one as well? |
Try it and find out
you can always reconnect wires. I would assume it wouldn't affect it however considering if the LED it burnt out of the other light then it probably isn't completing the circuit.
Yeah, I'll give that a shot in the morning then.. maybe you'll be able to see my car around phoenix! XD
Yep, you can try to remove the connection from the led lights, and try to reconnect them. Or rather, only try and connect the led and see if they are functional.
Don't be surprised with lights like those.
![]() ![]() Drives: '08 Yaris LB Join Date: Oct 2008
I just picked up a pair as well off eBay and had the same issue. Simple fix was to go to Radio Shack. They have small white LED's that are the same size that you can solder in place of the old ones. Works great now.
| electrical problem with car need help badly!! | Adriaan | DIY / Maintenance / Service | 20 | 05-07-2010 01:40 AM |
| Cruise Control pulsing problem. | rg570lvr | General Yaris / Vitz Discussion | 14 | 12-07-2008 05:55 PM |
| Yaris 06 H/B Engine Cutting out problem.. | Farenheit | General Yaris / Vitz Discussion | 3 | 09-14-2007 02:21 PM |
| HELP!! HID problem | 07yaris_fe | General Yaris / Vitz Discussion | 2 | 11-20-2006 07:00 AM |
| Service Problem | Lizardboy | DIY / Maintenance / Service | 19 | 10-06-2006 10:12 PM |
