Old 11-17-2008, 07:30 PM   #1
stran
Drives: '07 Yaris 3D HB Auto
Help Needed: Unlink A/C to Defroster
I don't like the way how the A/C has to be on when I turn on the front defrosters. I think there are two ways to fix this: fake out the detector switch so the car doesn't know you turned on the defroster, or kill the circuitry that automatically turns on the A/C.
In case you don't have the Factory Repair Manual Handy:
http://www.etimago.com/yaris/repairmanual/EWD.pdf
http://www.etimago.com/yaris/repairm...nditioning.pdf
This might get a little technical:
Option 1
One guest is that the switch could be inside the control knob itself, and the signal could be turned off by shorting the signal wire or soldering in a resistor. Take a look at page 245 of the Air Conditioning manual for more info about this. Or there could be a switch in the air damper that controls flow to the front defroster. See page 10.
Option 2
The Electrical Wiring Diagram Manual (filename: EWD.pdf) on page 239, 240, and 330 mentions "Defroster Mode Detection SW" in the context of air conditioning. SW means switch. The problem is that I don't know where this switch is physically located in the car. The diagram on page 50 and 52 might help answer this question but I can't put the two together.
Any help is appreciated, and I know I'm not the only person who wants to get rid of this.
stran is offline   Reply With Quote
Old 11-17-2008, 07:40 PM   #2
TheRealEnth
Beast
TheRealEnth's Avatar
Drives: 2007 Blz Blu LB
i really dont mind?
Its a Chao!!!
Old 11-17-2008, 07:48 PM   #3
IllusionX
Drives: 07 Yaris Sedan Aero
there IS a switch inside the knob that activates the compressor AND THE BUILT IN HEATER...
you do not really want to get beyond that that in messing around the wires...
Old 11-17-2008, 08:28 PM   #4
auxmike
auxmike's Avatar
What about in the deep of winter, will the A/C still kick on?
Old 11-18-2008, 04:09 PM   #5
stran
Except the connection to the heater is probably via a mechanical linkage. I know that the vent knob operates via a mechanical linkage. With the car off and there's no power, you can still switch between the vents. On luxury cars I've driven before, the soft buttons activate a little motor that open and closes the damper that only works when the car is on.
Old 11-18-2008, 04:21 PM   #6
The knob that changes where the air is blowing does so by cable as you mention. Here are some pictures of what the back of the switch assembly looks like:
From this thread about changing the bulbs:
http://www.yarisworld.com/forums/sho...light=led+dash
If you look at the close-up picture above the outer knob turns a plastic gear. I would bet that there is a boss on the gear that bumps a switch that parallels the AC switch. If so, you could just clip the boss...
Old 11-18-2008, 04:37 PM   #7
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
Seeing as you have it all apart anyway can you give us a pic of the cam/boss that activates the air while in defrost mode? dont know why Toyota couldnt have given me the option of defrost with air on or off,like its only a matter of pushing a button if i want the air on.
Old 11-18-2008, 04:46 PM   #8
I haven't actually pulled mine apart. I just remembered seeing the picture of it pulled apart on that thread. Based on the EWD's I think that the "option" is based on whether or not you have the "cold weather package".
Old 11-17-2008, 09:04 PM   #9
Option 1
Option 2
I looked at the EWD. To disable it you would need to cut a trace on the printed circuit board for the AC switch assembly. I would have to pull one apart to figure out which trace, but the other option is to replace the switch. The EWD indicates that there is one "w/ Defroster Mode Detection SW" and one "w/o Defroster Mode Detection SW".
Old 11-18-2008, 03:19 AM   #10
Revsson
Option 1
Option 2
It doesn't say it in your profile, but I assume that since you joined in 2007,
that you drive an '07 LB?
Just trying to clarify if there can possibly be any difference in the model
years for the A/C.
Old 11-18-2008, 05:18 AM   #11
jambo101
jambo101's Avatar
I don't like the way how the A/C has to be on when I turn on the front defrosters. .
I dont like it either,seems like a waste of energy,all previous cars i've owned never had air and i never had a defrost problem, but what is needed to defeat this operation looks like more trouble than its worth so i'll just crank up the heat a little more to overcome the permanent air when in the defrost mode
Old 11-18-2008, 07:32 AM   #12
floydisrock
73 Centurion droptop 455
floydisrock's Avatar
Drives: 2009 S Sedan
The ac compressor in a vehicle should be run to prevent clutch and bearing problems.
Every Car I've owned mentions running the ac at least once a month.
I'm guessing they just let the compressor run,so they don't have so ,many warranted a/c compressors to replace.
I wouldn't worry about the few cents your going to save disconnecting the unit,I would worry about replacing a $1000 a/c compressor.
"THIS SITE HAS BEEN HACKED BY www.bimmerfest.com. YOU FUCKERS!"
floydisrock is offline   Reply With Quote
Old 11-18-2008, 08:13 AM   #13
jambo101
jambo101's Avatar
My winter setting is the defrost/floor position for the entire winter so i guess i have no other option than to have the air running all winter whether i like it or not.
Old 11-18-2008, 09:08 AM   #14
IllusionX
you don't NEED to run with defrost/floor all winter long... put it back to the floor only when the front window is defogged.
Old 11-18-2008, 10:49 AM   #15
jambo101
jambo101's Avatar
Tried that and the windows start fogging up again,seems some airflow is constantly needed on the window to keep it fog free' but just warm air will do the job once the car is at operating temperature,at that point the air is no longer needed but there is no way to turn it off and still have airflow over the window.
Old 11-18-2008, 04:11 PM   #16
stran
agreed. i also like having warm air diffused instead of concentrated at my face or feet, and the best way to do that is through the defroster vents.
Old 11-18-2008, 08:57 AM   #17
winter or not, I believe the main reason for the AC kicking in is to dry out the air to help with the defrosting/defogging itself?
Old 11-18-2008, 04:05 PM   #18
stran
years for the A/C.
I have a '07 hatchback.
PS How do I subscribe to a thread if I forget to do it when I post?
Gas mileage and A/C Chaad32 General Yaris / Vitz Discussion 18 01-29-2009 04:31 PM
Do u guys set to Fresh Air for A/C? hans_fh General Yaris / Vitz Discussion 17 06-12-2007 03:24 PM
A/C & Aftermarket intake KSIbucky DIY / Maintenance / Service 2 03-26-2007 09:08 PM
A/C smelling weird? Yaris_PR General Yaris / Vitz Discussion 11 08-04-2006 08:26 AM
