![]() ![]() ![]() Drives: Polar White Yaris HB Join Date: Dec 2008
Stiffer suspension - same ride height?
I would love to have a stiffer more responsive suspension but I am not real thrilled with dropping the ride height. Are there spring spacers???
For example if and Eibach pro kit drops the front and rear by one inch, is there a one inch spacer to regain the original ride height??? |
QUACK~!!!!!
i remember the pre-hack, someone on here did a whole post on the spring spacer that you have mention but i remember it was for only the rears, not sure about the fronts
" ... I don't follow, thus i reign SUPREME . The only time i follow is when i follow my dreams ... "
Drives: yw calls me douche and racist. Join Date: Aug 2007
Call up Eibach. They'll do custom stuff like that.
![]() ![]() ![]() Drives: 2010 Mazda3 iTouring Join Date: Jun 2007
Maybe you can use the TRD shocks with the stock springs, I don't see why you couldn't.
I put TRD springs on mine, but with the 205/40/17s I had previously installed, I had major rubbing issues. The solution I found was spring rubbers. They brought the car back up some (I used 3/4" rubbers) and solved the rubbing problem. More cool is they stiffened the car up significantly. These are what NASCAR uses to adjust suspension on the fly during a race. If the car is too 'tight' they remove a spring rubber. If it's too 'loose' they add one. They are cheap too. The set (2) I got for the front cost $20 on Ebay. You can get them at a racing supply store too.
The rear I did differently. I go to cycling events and have a Hidden Hitch with a hitch rack on my car and I also take alot of gear with me also. The car was really dropping in the rear under the load, so I got some Monroe Adjustable Air Shocks. These run with @ 30lbs level the car to match the front, and also stiffen it too. When I go to a race, I add air to take the extra weight. I take it out once I'm back home. Just my redneck way of getting a better suspension cheaply. I run the twisty mountain roads where I live and I needed to be able to keep it on the road better.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB |
i have some eibach prokits 1" drop if you wanna buy 'em...
otherwise TRD or tokico blue shocks w/ stock springs would firm stuff up w/o a change in height...
OR coilovers set to minimum drop, although I don't know what that is for each brand.
Hmmm, thebarber's Eibachs sound good. Calling Eibach for a custom set of psrings. I wonder how much that would cost? Do you guys know anyone who has done this? Any other ideas? Custom machined spacers?
I was looking at JC whitney it looks like they have 1" rubber spacers
http://www.jcwhitney.com/Coil-Spring...3419_10101.jcw With spacers people could fine tune their ride height cheaply. I am just not sure if these can be used on the rear. |
#10 | |
![]() ![]() ![]() ![]() ![]() Drives: Scion FRS RS2, ‘21 Crosstrek Join Date: Oct 2008
Adding TRD shocks / struts to the otherwise standard suspension would definitely stiffen things up and improve handling preformance. Throw in a TRD rear swaybar as well and you'll be good to go at OEM altitude.
TRD Upgrades: 18" Wheels wrapped in 215/35/18 PZero's, Sportivo Shocks/Struts, Lowering Springs, Swaybar, Axle-Back Exhaust, Oil Cap, Rad Cap, Signage. Aftermarket Goodies: Piggies SS, K&N Drop-In, Blitz S/C, DC Header, NST Pulley) Toyota Options/Accessories: Sport Pedal Covers, Sport Shift Knob, Ipod Interface, Summer Mats, Winter Mats, Cruise Control, Auto-Dim Mirror, Echo steelies with winter boots.
#11 | |
Who said Yaris was slow?
It was Loren (Our local suspension guru) who brought up the subject of the rubber spacers from JC Whitney. If I remember correctly he ran some of those in the back of his car with the stock springs for some autoX events. They managed to increase the ride height and stiffnes. And you can use them on the front as well. ![]() You could go for Some Tanabe NF springs (1" drop) + rubber spacers and probably end up pretty close to the stock height. |
Hmmmm, there appears to be quite a difference in the diameter between the front and rears. I will go to the JCWhitney website to see what size are avaliable. Can anyone help me out with this??
Combining spacers of different widths seems to be a good way of tuning ride height. Anyone else try this??? |
Why not go with a eibach pro kit its a very light drop and much stiffer than stock. The ride height is already very high. You would have any issues with scraping still. If you are really adamant about keeping stock hight but awnt to have a stiffer ride then go with tokiko blue shocks they have higher valving. Or maybe you could just order some extra bump stops and stack them. I supose that would work too. You could do that for the front and then just order tokiko shocks for the rear only.
| Finishing my suspension | ChinoCharles | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 11 | 10-15-2011 09:26 PM |
| What suspension for my driving? | narkeeso | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 7 | 08-02-2007 08:39 PM |
| Megan or Tein suspension | elmercurrie | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 43 | 05-31-2007 09:41 PM |
| stock ride height or spring sag? | mikeukrainetz | General Yaris / Vitz Discussion | 5 | 12-21-2006 01:00 PM |
| Air Ride suspension for Yaris Sedan | fouad84 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 7 | 10-13-2006 07:39 AM |
