Old 05-16-2007, 05:11 AM   #1
elmercurrie
foreign oil = dependence
elmercurrie's Avatar
Drives: 3 door
Megan or Tein suspension
Question? I'm trying to find the best suspesion to lower my Yaris, the "Tein Basic" looks pretty good, but offers no adjustment to the shocks (dampening, I guess you would call it) only ride height, I've heard a lot of good things about it though. Megan Racing has a coilover kit too, it's called the "Megan Coilover Damper Kit " and you can adjust the ride height and shock dampening. I haven't heard of either of these companies before, until I found this site (Yaris World), and I've read no reviews of the Megan suspension. If anybody has knowledge of both systems or even is using one or the other and can offer an opinion I would greatly appreciate it.
Many thanks, Elmer
elmercurrie is offline   Reply With Quote
Old 05-16-2007, 09:17 AM   #2
Imagine
Insert sarcasm here.
Imagine's Avatar
Drives: 2009 Black Pearl Sand 3Dr
The one thing to keep in mind is the ride quality. I was researching the two and noticed that the Megan coilovers have a much higher spring rate then the Teins did. This could attribute the a much more harsh ride, but it would be good if you planned on racing it.
Thats really all I know. Tein is a lot more well known, and probably a more comfortable daily driver suspension. Good luck with your decision let us know what you decide. I'd be VERY interested to hear some reviews on the Megans.
Imagine is offline   Reply With Quote
Old 05-16-2007, 01:47 PM   #3
R0ME0
Drives: '00 Toyota Celica GTS Turbo
I'd go tein all the way!
R0ME0 is offline   Reply With Quote
Old 05-16-2007, 06:41 PM   #4
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
Well, I have decided on Megan but it will be another month or two before I get them installed.
SPONSORED BY
Old 05-16-2007, 07:00 PM   #5
churp
Clean and (dis)Functional
churp's Avatar
Drives: Yaris 2dr--Black Betty
Do you have to contact the company direct to get info? I have Megan springs (NOT coilovers) and haven't found any info on spring rates. It's much firmer than a stock AW11 MR2 but softer than my 80 RX7 (but this RX7 is firmer than others I've driven..don't know what's been modified), but exactly how I like them...street/daily driver and no racing. Let me know if there are any sites listing comparisons of rates...I'm interested.
____________
Old School Cobble Jockey
churp is offline   Reply With Quote
Old 05-16-2007, 07:14 PM   #6
brickhardmeat
Lonesome Cowboy
Megan Coilovers Spring Rates: 6kg Front and 5kg Rear and Tein F:4k R:3.1k
matter of fact here are all the specifics
Megan Coilovers Features:
32 Levels of Adjustable Damper
Rubber Dust Covers.
Adjustable Ride Height
Aggressive Spring Rates
Single-Cyliner Design
Aluminum Brackets
32 Levels of Adjustment:
1-8: Suggested for track use.
9-16: Suggested for mountain/aggressive use.
17-32: Suggested for common street use.
All coilover damper kits come with 1 year manufacture-defect warranty.
All Hardware is Included
SELLING PRICE : $895.00 per set.
Tein Specifics
Spring Rate:
Front: 4 kg/mm / 224 lbs/in
Rear: 3.1 kg/mm / 174 lbs/in
Ride Height
Front: -1.9 in
Rear: -1.9 in
Ride Height Adjustment
Front: -1.3 ~ -2.8 lbs/in
Rear: -1.2 ~ -3.0 lbs/in
TEIN Type BASIC damper is for the driver that is seeking high performance with a reasonable price. The Basic damper MSRP starts at $750.00, which includes 4 springs and 4 shocks. Compared to the "sleeve type" coil over, the Type Basic has a more exclusive set up for a better balance of suspension travel and damping force.
High performance and cost effective.
Ride Height adjustable.
New paint coating for rust prevention.
Exclusive design for USA vehicle specifications. (only available for the U.S.A Market).
Available for overhaul.
Contents of damper kit
Height Adjustable shock absorber x4
Main spring x4
Lower spring seat x4
Seat lock x4
Thrust washer x4
Bump rubber x4
Dust cover x4
just for fun the Tanabe DF210 are Spring Rates F/R 3.0 / 2.2
SPONSORED BY
Last edited by brickhardmeat; 05-16-2007 at 08:50 PM. Reason: Tein are only 910. we are not talking much price difference at all here.
Old 05-16-2007, 07:25 PM   #7
churp
churp's Avatar
Do the coilover rates have any similarity to just the lowering coil rates? (say for the Megan springs?)
____________
Old 05-16-2007, 07:29 PM   #8
brickhardmeat
Lonesome Cowboy
Well, judging by the Tanabe spring rates I listed yes I guess so but the Megan Racing Springs say for the Yaris, (Note: Spring rates and drop amount vary by different vehicle application and chassis load.)
They do however list spring rates for other applications. Leads me to believe the spring rate for Yaris is yet to be determined.
Various spring rates for megan racing springs I have found are anywhere from 200 to 350.
SPONSORED BY
Old 05-16-2007, 08:52 PM   #9
don't feel like reading through the replies right now, but from my experiences with these two companies, i'd go with Tein. i had lowering springs from Megan on my GTI when i had it, and i have Tein springs on my Yaris. the Megan springs promised a two inch drop, but i only got, at most, a 3/4 inch drop. the S.Tech's did what they said they would. oh, and the Megan springs were not at all stiffer than the OEM springs.
Old 05-16-2007, 08:55 PM   #10
brickhardmeat
Lonesome Cowboy
but we are talking about adjustable coilovers for the most part here, that is how the thread originated
SPONSORED BY
Old 05-16-2007, 09:42 PM   #11
ColinT
ColinT's Avatar
Drives: '07 Yaris LB
Send a message via AIM to ColinT
From what I see the megans are a better choice. Stiffer, threaded strut mount (dosnt limit travel when lowering) and they seem to be of alright quality. The shocks are made by Bor Chuann ( http://www.bcec.com.tw/ ) which are rumored to make Apexi shocks but I don't know for sure. Also the springs look to have a very similar finish and text to the Cuscos. Once again I don't know if that means anything. The thing that really needs some improvement is the instructions, pretty vague and written in poor english.
I be putting a set on Friday and Ill give a review then. Please bear with me as my composition skills are not the best.
The only thing that bums me out on them is that all of Megans other applications come a lot more cool stuff for the same price. (pillow balls)
ColinT is offline   Reply With Quote
Old 05-17-2007, 01:42 AM   #12
i know, just giving feedback about the companies. then again, Megan can suck with springs, but excel in coilovers.
Old 05-17-2007, 08:52 AM   #13
ColinT
ColinT's Avatar
Megan seems to be a company that outsource everything they sell. So quality can vary greatly from product to product.
Old 05-18-2007, 08:08 PM   #14
Imagine
Imagine's Avatar
Awesome! I'll be looking forward to hearing your thoughts.
Old 05-18-2007, 10:31 PM   #15
brickhardmeat
Lonesome Cowboy
off subject somewhat for this thread but how did your springs settle? did you end up with 1.5 drop a little more less? have you measured?
SPONSORED BY
Old 05-19-2007, 12:48 AM   #16
churp
churp's Avatar
Measured after a couple weeks and its probably more like a 1.375 drop both front and rear. Carried a load of 4 truck tires w/rims to a friends today (parting out Big Bertha the van, who needs a truck when you have a LB)....actually think I would have to try hard to ever bottom out. Firm, the way I like it.
____________
Old 05-19-2007, 01:06 AM   #17
dngz
dngz's Avatar
Drives: black yaris sedan
i think ill be going for the megR coilovers. The quality of the tein basic is probably the same as the megan racing for I believe they are both made in the US. Only the higher model teins are made in Japan. If you want super quality and you want it nice on the street, Id say go with cusco. I'm just going with the Megan Racing cuz I want the option of adjusting the dampness..
dngz is offline   Reply With Quote
Old 05-20-2007, 01:13 PM   #18
brickhardmeat
Lonesome Cowboy
Well, vanderkitten has the megan coilovers installed and we should be in for a full review very soon. Also holding out for a review from colint think he installed this weekend also.
SPONSORED BY
Finishing my suspension ChinoCharles Wheels, Tires and Suspension Forum sponsored by The Tire Rack 11 10-15-2011 09:26 PM
Any Yaris hatch rear suspension tweeks? woof Wheels, Tires and Suspension Forum sponsored by The Tire Rack 26 12-05-2009 06:04 PM
TEIN - Basic Coilovers *Now Available* EnduroMTS Sponsors Classifieds Area 4 10-13-2006 02:43 PM
TEIN Basic coilovers C2AUTOSPL Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 06-26-2006 01:57 AM
