![]() Drives: 07 Yaris 3dr, 09 Yaris 4dr Join Date: Sep 2011
Thermostat Question
Does anyone know for sure whether the thermostat in my 07 Yaris will stick open or stick closed in the event that it fails?
It really can fail either way, but I think it would more likely stick closed.
![]() Drives: Yaris 2007 Sedan Join Date: Dec 2012
If your car takes longer than usual to warm up in the winter.. it's likely sticking open.
![]() ![]() ![]() Drives: 2009 yaris 2 door Join Date: Feb 2013
stick open
In my past experience when folks mix the wrong coolant in the system it corrodes/rust the thermostat and it fails open, or actually there is gunk keeping it slightly open and makes the car's coolant system run colder than normal.
only use the coolant specified for your car and only mix distilled water to avoid problems. |
#6 | |
![]() ![]() Drives: Yaris 1.33 litre 2011 Join Date: Dec 2009
Regards Geoff Peace. |
| Need advise (Radiator Hose/ Thermostat Gasket) | vellano | DIY / Maintenance / Service | 7 | 12-12-2012 11:37 PM |
| Question about bi amping front components. | YarisSedan | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 08-28-2010 12:04 PM |
| ctrl-alt-delete question & free anti-virus question | Shroomster | Off-topic / Other Cars / Everything else Discussions | 18 | 09-08-2009 03:57 AM |
| Amplifier Watt Question....noob question | hasher22 | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 09-27-2007 03:59 PM |
