Old 08-25-2010, 05:59 PM   #1
YarisSedan
Drives: 08 Yaris Sedan
Question about bi amping front components.
So i have components on the front that are on a passive crossover. The crossover has the option to be bi amped. Would it be better to run new wiring from the second amp to the speakers on the doors and let the amp crossover LP handle the mids. And another amp separate to the tweeters setting the HP setting to the tweeters.
Although easier is it more beneficial to just let the passive crossover handle everything.
Another question is to get the signal for the speakers in my door should i be getting a Y splitter to split the signal for the front 2 channels. The deck is a pioneer that has 6 rca outputs. 2 for the front which are currently setup for the front components and the 2 sub outputs for the rear subs. So i have 2 rear channel outputs that are still available. Will this mess up my sound staging if i use the rear rca output to power the mids in the doors while the vocals from the highs are by the pillars from the front rca outputs.
Another question is to get the signal split for the front is there any particular brand Y splitter i should use that is good.
Old 08-26-2010, 02:27 PM   #2
sqcomp
Roadrunner Jr.
sqcomp's Avatar
how's your EQ section on the source unit?
― Thomas Paine
Old 08-26-2010, 02:51 PM   #3
YarisSedan
Its actually pretty good. Has multiple preset options and custom option. Also can adjust the HP and LP with independent sub control. Although i have a analog eq i might install in the dash under the source unit. I just like the ease of control of analog and its easier to turn the bass down from the subs with the knob then trying to press through buttons on your cd player while trying to watch the road.
Old 08-26-2010, 05:27 PM   #4
sqcomp
Roadrunner Jr.
sqcomp's Avatar
Let me re-phrase that question...
What is the model # of your source. This will tell me how far you can go with your crossovers and EQ. This will tell us what we need to do with the passive crossovers (if we need them at all).
― Thomas Paine
Old 08-26-2010, 06:19 PM   #5
YarisSedan
Okay this is my entire setup.
The model number off the deck is Pioneer DEH-P49001B. http://www.pioneerelectronics.com/PU...4900IB.Support
My amp is Alpine 4 Channel MRP-F300
Front components are memphis audio MC 15-MSQ6 http://www.sonicelectronix.com/item_...s+15-MSQ6.html
Rear speakers are Tang Band W69-1042J 6"x9" Subwoofer http://www.parts-express.com/pe/show...number=264-837
I have sitting in my room a old memphis 4 channel amp - unsure of model number and power raiting. My guess is its probally simular to the 4 channel i currently have. Also have another D class memphis amp pb400. Its 200 watts x 2. Which i supose i could use to power the front woofers but not sure if this is too much power for them to handle. I used them to power 2 12" subs. Ideally I supose i could use my current amp to power only the front components and then use the D class amp to power the rear subs. But then again im not sure if its too much power for them.
and also memphis EQ model 16-EQP4 and also some tweeters.
Dont really wana go out and buy new equipment if i dont have to. I have all these leftover stereo equipment from my old car i took out before i sold it and bought my yaris. Would like to put it to use if i can. I know if i try to pawn it on craigslist i wont get even close to what i paid for it.
Old 08-28-2010, 10:51 AM   #6
sqcomp
Roadrunner Jr.
sqcomp's Avatar
It looks like this piece has three pre outs. Is this correct?
― Thomas Paine
Old 08-28-2010, 12:04 PM   #7
YarisSedan
Yes.
Tanabe Front Tower Strut Bar Question B-Rock21 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 2 08-21-2010 04:15 PM
Another question about car audio wiring for rear components YarisSedan In Car Entertainment + Electronics (audio / video / alarm) 0 08-16-2010 09:39 PM
Yaris front strut install question PHXDEMON DIY / Maintenance / Service 20 07-10-2010 10:30 PM
Installed 6.5 components with crossover but have a question... YarisSedan In Car Entertainment + Electronics (audio / video / alarm) 7 03-01-2010 12:22 AM
Stupid Front bumper question (sedan) amishpriest General Yaris / Vitz Discussion 17 07-26-2006 03:10 AM
