Old 04-20-2009, 09:40 PM   #1
Taiyaki
アキバ製
Taiyaki's Avatar
Just changing the blubs?
So I have been told that just changing your stock blubs with like Nokya or other kind of thoes blubs will damage your wires or something, and others say that they have been driving with them forever and nothing happened.
I want to pretty much change the head light bulbs, reverse bulbs, and maybe license plate bulbs.
So does changing them damage your wires?
Old 04-20-2009, 10:24 PM   #2
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
i think you will be ok with running the nokya BLUBS. :)
Old 04-20-2009, 10:29 PM   #3
severous01
run the oem wattage bulbs. anything higher than oem wattage will hurt wiring.
Old 04-21-2009, 02:30 AM   #4
Spades
The Hated One
Spades's Avatar
Drives: 07 White Manual Sedan
Disagree...depends on the temperature of the bulb and how much wattage it is pulling. some bulbs of the factory wattage put out so much heat they melt the harness.
also, from my experience, a bulb that pulls a few more watts than factory wont fry a harness, but if its alot more, expect problems.
It is just like any other wiring, including home electrical. the wires in your house leading to your light bulb fixture are meant to have a certain amount of current running through them...if your home fixture recommends a 45 watt bulb, if you put a 120 watt bulb in it, expect the socket wiring to melt or the wires leading to the socket to melt and cause a fire.
same deal with your car. will a 5 watt higher bulb ruin the wiring harness? doubtfull, but if it does, dont expect warranty coverage and expect all the naysayers to say "i told you so"...
Old 04-20-2009, 10:55 PM   #5
Taiyaki
アキバ製
Taiyaki's Avatar
Where can I find the wattage of each bulb?
Old 04-21-2009, 04:16 AM   #6
Taiyaki
アキバ製
Taiyaki's Avatar
Ok I understand. So is there a site that shows the watts thats stock bulbs use? can not seem to find info on them.
Changing LED's In Projector Head Lights whooppee777 Cosmetic Modifications (Exterior/Interior) 16 03-01-2009 02:07 PM
Changing the oil lita_g DIY / Maintenance / Service 18 10-28-2008 01:59 PM
Changing Headlight Bulb Tutorial RSboyz DIY / Maintenance / Service 29 03-15-2007 01:35 PM
About Engine Oil Changing Manual hans_fh DIY / Maintenance / Service 4 03-03-2007 10:20 AM
Changing to 60/40 seats? NickNickNick General Yaris / Vitz Discussion 1 05-14-2006 04:08 PM
