Old 03-03-2007, 04:38 AM   #1
hans_fh
About Engine Oil Changing Manual
My Yaris is the first car in my life. It is reaching 5,000 miles right now. I have never changed engine oil for my car before. Does any one have a manual for changing the engine oil/filter for Yaris? Or can someone introduce it briefly?
Thanks a lot!!
hans_fh is offline   Reply With Quote
Old 03-03-2007, 06:16 AM   #2
spkrman
Drives: 1
google up how to change oil and everything will be there.
Everything is right under the car on the passenger side, absolute piece of cake to change.
Old 03-03-2007, 10:02 AM   #3
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
The hardest part is getting under the car and having enough room. DON'T overtighten your oil drain plug when you reinstall it.
Quick and simple version-
1. Make sure the engine is fully warmed. With engine off, remove oil drain plug and drain all the oil.
2. Reinstall plug and torque to specs in manual.
3. Unscrew oil filter and remove while being careful not to dump hot oil down your arm.
4. Take new filter and fill it with oil nearly to the top.
5. Install new filter. (Filter box will say how tight)
6. Fill with oil. (check it on the dip stick)
7. Start engine and run for two mins. Turn engine off for two mins.
8. Check oil and top off if nessasary. (Don't overfill the oil past the max line)
Old 03-03-2007, 11:09 AM   #4
Violin
Violin's Avatar
Drives: 2007 Yaris LB Auto
(drain the oil into a catch pan and dispose of properly)
Old 03-03-2007, 11:20 AM   #5
tekmoe
ex-yaris owner
Drives: 08 solstice gxp, 06 triumph s3
Send a message via AIM to tekmoe
the yaris is by the far the easiest oil change i have ever done with regards to where the oil filter and drain plug are at. when i changed the oil a couple of months ago (first oil change since it came from the factory) the oil filter was an ABSOLUTE bitch to get off. they always overtighten the freakin' things at the factory. totally unnecessary. get it on their hand tight and then add about 3/4 of a turn. that will be more than enough. then when you are ready to do the next oil change it will be much easier to get off.
tekmoe is offline   Reply With Quote
Fuel Economy swng Fuel Economy Forum 2089 01-23-2015 07:41 PM
Help with oil change specs autophile DIY / Maintenance / Service 31 04-25-2011 10:22 PM
metal particles in oil 007 hatch DIY / Maintenance / Service 9 06-22-2007 03:56 AM
Are you changing your oil at 5k mile interval recommended by Toyota? Yaris_Fan DIY / Maintenance / Service 24 01-30-2007 12:54 PM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 09:16 PM
