Old 05-26-2009, 10:21 PM   #1
TitaniumBarbell
TitaniumBarbell's Avatar
Drives: Yaris 3Dr LiftBLACK
Have an Cold Air Intake question...
Hi to everybody! I bought a brand new TRD Cold Air Intake.
First, I installed it with my neighbor and removed the battery negative pole during installation.
2nd, after installation, I turn on the car for 20 minutes and ran the car (like 60 miles per hour).
The third day, the check engine advise is on.
I repeat the steps but in the second day turn on again the check engine advise.
I verified the temperature sensor and it's ok.
What do you recommend me?
Thanks!
Modz: 5" Antenna ↘ %35 Tints ↘ Seat Covers ↘ OEM Mudguards ↘ OEM Rear Bumper Protector ↘ Dash Carpet Protector ↘ Valor Tip ↘ Interior LED Lights ↘ Hyper White H4 Lights ↘ Fog Lights ↘ RS Spoiler ↘ 15" OEM Alloys ↘ TRD Springs ↘ TRD Rear Sway Bar↘ TRD CAI ↘ Black RS Taillights
Changed Oil/Filter ↘ April 28, 2009.
TitaniumBarbell is offline   Reply With Quote
Old 05-26-2009, 10:32 PM   #2
Brian
Brian's Avatar
Same thing happened to me. The light should go away in a day or so. I think its just the computer has to adapt to the new intake.
Old 05-28-2009, 08:26 PM   #3
TitaniumBarbell
Thanks!
Old 05-29-2009, 11:44 PM   #4
TitaniumBarbell
Now, the check engine advise appear and dissapear, it depends if I go slow or fast. If I go fast, check engine light appears.
Old 05-30-2009, 11:33 AM   #5
YarisPR
YarisPR's Avatar
Drives: Yaris Sedan
Desconecta la bateria por la noche y conectala por la manana. Y dale break, cm t dijeron el carro se adapta.
I Drive a 129whp Yaris ;)
YarisPR is offline   Reply With Quote
Old 06-01-2009, 12:20 AM   #6
Qmobile
that's right I went there
Qmobile's Avatar
Drives: '08 Blazin' Blue,'10 Dark Red
Yikes! I want that same intake hmm......
Mods: 15" SSC rims, TRD Exhaust, TRD Sway bar, TRD oil filler, TRD rad. cap, TYC tails, Debadged, Painted engine cover, Stock spoiler, Stock mud gaurds, OBX pedals.
suggestions always welcome
Qmobile is offline   Reply With Quote
Old 06-01-2009, 12:29 AM   #7
make sure the maf sensor is seated and sealed properly. most common cause of CEL when changing the intake.
Old 06-01-2009, 12:39 AM   #8
bzinn 1
bzinn 1's Avatar
Drives: 2008 Yaris HB
yep check your connections to make sure the clamps are tight and the MAF is secure and sealed.
Old 06-01-2009, 05:18 AM   #9
TitaniumBarbell
Thanks for all your replies. Ill verify everything on my off-day.
Old 06-01-2009, 12:15 PM   #10
severous01
ya....get some thin foam and cut to make a seal around the sensor. that will seal it and keep water out as well.
also, you have to realize that you're pullin much more air and a sensitive sensor may be on the high end of the scale any way...so you may have to just give it a while and let the ecu adjust.
another thing is...it takes about 1500 miles before the ecu will learn your driving habits so give it some time...a couple tanks of gas at least. unless you're gettin like 10 miles per gallon. then you have a problem
Old 06-02-2009, 04:24 PM   #11
Kioshi
Heart Up! Vitz
Kioshi's Avatar
Drives: トヨタ Vitz
make sure everything is tightly secure. Give the intake a good pull where the hose clamps are put, it should be very tight, no movement what so ever.
I have a f5 intake, and never had a cel thrown at me, been over a week of having it, and driving 300+ miles already on top of it...
Good luck
Cold air intake vs air intake Liu997 Performance Modifications 15 11-05-2009 05:32 PM
Simota Carbon Charger Cold Air Intake lilredrocket Performance Modifications 18 04-13-2009 03:16 AM
