Old 12-06-2008, 12:47 AM   #1
lilredrocket
Slowy getting there
lilredrocket's Avatar
Drives: 08 Liftback
Simota Carbon Charger Cold Air Intake
So I got my intake on thursday and put it that night after work. I was thinking about putting on this weekend but was to excited to wait. I am very happy with and the service that I got from kargoboy was amazing. delivery was faster than expected. The install was really easy on a scale from 1-10 with 1 easy it was probably a 2 cause you have to force the pick up tube by your head light may sound bad but really was not. So here is the process couldn't find one on this and if there is here is a newer one pictures and all. Enjoy sorry they are a little out of order.
This is what it looks like before it is touched there are two hose clamps that need to be removed on the tube going from the throttle body to the air box. There is a hose on the back side of this tube with a little clampthat you can pinch with your fingers move it up the line cause you will reuse it pull the hose off. Disconnect the Mass Air Flow sensor harness there are a couple of little clips holding it to the stock system you can brake those off if you like or fight them like I did. Unclip the top of the air box now you can pull it off with the intake hose with it now you can swich the the MAF over to the new intake tube make sure it is facing the right way.
Attachment 14057
This is everthing that comes with the kit.
This is what it looks like assembled w/o clamps
After the top of the air box is off and the MAF is swiched over. Remove the air filter and there are 2 bolts in the bottem those need to be removed to take out the bottem of the air box. They are 10mm bolt heads.
This is with the stock air box removed and the bracket under it too (sorry no pic of the bracket i was still really excited). The bolts holding the bracket have a 12mm head. One of the bolts will reused for the bracket in the kit. I used the hole in the front.
This is the whole air box put back together with the the bracket no the bottem for storage. Big difference in size and weight.
This is everthing installed sorry no pictures half way through got carried away again. Install the MAF tube with the adaptor for the throttle body clamp it. then slide the tube with the little clamp still on it and reclamp it. To install the filter leave the main pick up tube clamped on it with the elbow because force is needed to slide the pick up tube between the wires under the head light. now find a way to install the last rubber adaptor and the mounting bracket. It shows how I did my bracket. Just a suggestion.
I took off my bumper to show what the pick up tube looks like behind the bumper. This is not a nessecary step I just wanted to see it and get a picture
Over all driving the car I am very happy with it. I drive around with a grin on my face. At WOT I tell everyone that my car sounds pissed off. Just sounds really cool which is why the strictly fuel economy moders won't like my review cause it sound to cool not to let it make that noise. Haha..
Old 12-06-2008, 03:12 AM   #2
msfire671
ONE LOVE...YARiS LOVE!!!
msfire671's Avatar
Drives: Toyota Yaris
Send a message via MSN to msfire671 Send a message via Yahoo to msfire671
i want one....how much did yah get for it??
ive searched this on youtube....its a beast!
msfire671 is offline   Reply With Quote
Old 12-06-2008, 03:22 AM   #3
lilredrocket
Slowy getting there
Drives: 08 Liftback
I got it from Kargoboy at www.yarisuniverse.com for $130 US.
Old 12-07-2008, 12:35 AM   #4
msfire671
msfire671's Avatar
wow...only $130...no bad at all! thanks!
Old 12-07-2008, 12:50 AM   #5
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
Good DYI
Old 12-07-2008, 01:00 AM   #6
msfire671
msfire671's Avatar
whats the diameter on a sedan? 3"??
Old 12-07-2008, 08:53 AM   #7
bxrich
bx in the house
Drives: toyota yaris sedan
msfire671 it fits the sedan. i have with a little costum work.
bxrich is offline   Reply With Quote
Old 12-07-2008, 08:56 AM   #8
bxrich
bx in the house
good diy now go and clean your bay to show it off right.
Old 12-07-2008, 09:21 AM   #9
lilredrocket
Slowy getting there
Drives: 08 Liftback
Haha... Thank you... I went to the car wash already. It looks good now. Like they said this whole kit can fit the sedan with a little custom work but can also be used as a ram air too.
Old 12-07-2008, 09:52 AM   #10
Klink10
Klink10's Avatar
Mine has been in for awhile.......love it. Had to fab a couple of additional brackets to make it a cleaner appearing install and make it easier maint. wise.
Old 12-07-2008, 10:22 AM   #11
lilredrocket
Slowy getting there
Drives: 08 Liftback
^ looks nice. I looks like you did it ram though.
Old 12-07-2008, 01:59 PM   #12
Klink10
Klink10's Avatar
I did yes....could not for the life of me get the downpipe to go in the space provided. I'm still playing with routing in my mind but am in no big hurry.
Old 12-07-2008, 05:43 PM   #13
jinxor
jinxor's Avatar
Drives: Yaris 3dr YRS
Mods can even transfer this post to the diy section... Good write up mate...
Old 12-07-2008, 07:53 PM   #14
msfire671
msfire671's Avatar
looks great...but still didnt answer my question...
is the diameter 3" or a 2.75"
im placing an order for one and i just want to make sure that its the right size.
btw....
Old 12-07-2008, 09:42 PM   #15
lilredrocket
Slowy getting there
Drives: 08 Liftback
btw....
PM kargoboy he will know but I'm pertty sure it's 3"
Old 12-07-2008, 10:24 PM   #16
kargoboy
kargoboy's Avatar
Drives: '07 Yaris Sedan/'03 Protege
btw....
I just sent you a PM, but now I am confused after reading this.
You ordered only a replacement filter encased in a carbon-fiber-looking
heat shield. The one you ordered fits a 3" intake tube.
That's not an entire intake, though, it's just a filter.
kargoboy is offline   Reply With Quote
Old 12-08-2008, 10:43 PM   #17
msfire671
msfire671's Avatar
thanks for the pm but yes i wanted one but im gonna have to settle with just the filter...and yes i will be saving up for the entire intake.
Old 12-08-2008, 11:51 PM   #18
ddongbap
I've said it once, and I'll say it again. My intake is the best.
ebay generic cold air intake -$40 marlondog Items for Sale by private party 2 11-16-2008 12:25 PM
guess what I'm waiting for and how much I paid? Ric n Sov's Vitz RS General Yaris / Vitz Discussion 27 06-27-2007 07:36 PM
cold air intake PolrWht07 Performance Modifications 8 05-28-2007 09:25 AM
Cold Air Intake vs. Short Ram Intake nevermorez Performance Modifications 1 01-24-2007 04:25 PM
