Old 05-03-2009, 06:43 PM   #1
schreck
Drives: 2009
Question Punching Air Box Holes
I've seen threads claiming that punching a couple of holes in the bottom of the stock box will add a minor amount of hp along with a satisfying growl on acceleration.
Question 1: Does this void the factory warranty?
Question 2: Doesn't adding holes to the bottom of the box allow for engine heat to be sucked in instead of cooler air? Wouldn't it be smarter to punch the holes in the front part of the box that faces the front grille?
schreck is offline   Reply With Quote
Old 05-03-2009, 07:13 PM   #2
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Probably won't void the warranty.
It may add some sound but just get an aftermarket intake that way if you have to take it in you can swap the stock airbox back on
Old 05-03-2009, 08:59 PM   #3
06silveryaris
Drives: 2006 yaris
I had it on my HB it sounds very deep. As far as the warranty just buy another bottom half of a airbox at the junkyard or used parts depot and cut that one.This way just swap before going to the dealership
06silveryaris is offline   Reply With Quote
Old 05-03-2009, 09:34 PM   #4
xen555
xen555's Avatar
Drives: 3 DOORS LB
cuanto te cobraron?
yo estoy buscando una pero no me lo quieren vender solo
es para un inventito que quiero hacer
xen555 is offline   Reply With Quote
Old 05-06-2009, 07:54 PM   #5
06silveryaris
Drives: 2006 yaris
Originally Posted by xen555 View Post
cuanto te cobraron?
nunca la cobre pq mi yaris no tiene garantia pues no tuve q ir al dealer en quebradillas hay un junker q tiene muchos yaris
Old 05-05-2009, 10:59 PM   #6
whiteghetto
whiteghetto's Avatar
Drives: '07 blazing blue hatch
I have done this
simota dry filter
swiss cheese airbox
I dont have numbers
but I would say
a little more power up top
does have a 'nicer' sound
if I am good I get better MPG (a few MPG)
2007 HB Blazing Blue
whiteghetto is offline   Reply With Quote
Old 05-05-2009, 11:05 PM   #7
YarisSedan
Drives: 08 Yaris Sedan
LOL i did this mod on my 240sx years ago. It seems like its a popular mod on every car forum i have ever been on.
Old 05-06-2009, 02:50 PM   #8
scape
scape's Avatar
Drives: 2007 Yaris Hatchback
there's no concern for excessive moisture at the stock filter?
Old 05-06-2009, 08:01 PM   #9
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
I doubt it, most of the cold air intakes go right under the headlight, and can be splashed if you go through large puddles.
Old 05-06-2009, 10:18 PM   #10
06silveryaris
Drives: 2006 yaris
I never ad any problems wit mine and it rains alot here
Old 05-07-2009, 04:59 PM   #11
eric81
eric81's Avatar
Drives: Toyota Salesman
I met with Astroman close to almost a year ago now, and he had a true CAI (one that goes to the bottom of the engine bay) and told me he cut the slits off of the back side of the fog light covers, to let in a little more cold air. According to his computer, it dropped the temp in his engine bay about 25*F. I bought a CAI a while ago, and just two days ago cut the slits off the back side of my fog light covers. I will most deffinately say there is some serious engine temp difference. I noticed my radiator fan took MUCH longer to kick on, and only came on after sitting for several minutes. That led me to my next experiment... cutting the bottom of the air inlet for the cabin air. Problem with that, is that there is a metal piece between the air inlet and the actual engine bay. I mostly wanted a way to cool off the upper side of the engine, since that is where heat goes (it rises). Also, being as far back a that air inlet is, it would do wonders to help cool off the header faster, without having to coat it or wrap it and degrade it's life span any. (Yes, wraps and sprays actually do shorten the life span of headers, ask anyone who has done it 2 years ago or longer). Great idea to make your own CAI. It is smart and cheap. And even looks stock from the topside. Sleeper comes to mind.
eric81 is offline   Reply With Quote
Simota Carbon Charger Cold Air Intake lilredrocket Performance Modifications 18 04-13-2009 03:16 AM
Does your yaris Engine and air box shake??? Yawesh General Yaris / Vitz Discussion 5 12-13-2008 04:20 PM
DIY: Custom Hidden Trunk Box (08 Yaris 3D) goku87 In Car Entertainment + Electronics (audio / video / alarm) 0 10-19-2008 05:43 PM
