Old 07-27-2009, 09:14 AM   #1
Lewis
Our off road vehicle
Lewis's Avatar
Drives: 2009 Yaris 3dr
Smile Info on 2010s?
I love my 2009 base 3dr but have to say their are 2 things that are included in other markets now - which my car doesn't have- and IMO really could use- that would get me to trade my 2009 for a 2010- stablity and traction control, and a tachometer on a stick shift model. Although it was easy and cheap to do also IMO every Yaris should come standard with the rear anti-sway bar- that's how much difference it makes!
Any word available yet on the 2010s and how they'll be equipped and optioned ed?
Thanks.
Lewis is offline   Reply With Quote
Old 07-27-2009, 12:33 PM   #2
TwoBearWisconsin
TwoBearWisconsin's Avatar
Drives: 2010 Yaris LB/5, 1996 Miata
Motor Trend is saying that the 2010 Yaris will have standard stability control. If you believe them...
TwoBearWisconsin is offline   Reply With Quote
Old 07-27-2009, 01:00 PM   #3
Lewis
Lewis's Avatar
I hope they're correct- it does become required by the Federal government at some point - a proven lifesaver- so why wait if you have it- and they do overseas.
I just hope they also fix the silly situation of offerring the stick shift model with no way to get a tach.
Old 07-27-2009, 04:10 PM   #4
Split
Drives: 2008 Yaris Sedan
Exclamation
i'm not sure why anyone needs stability control to be honest. i dont even use it in winter with my is300...as for the yaris, when its snowy, just ease off the throttle if you feel the tires slipping..
Split is offline   Reply With Quote
Old 07-27-2009, 05:02 PM   #5
Lewis
Lewis's Avatar
I think it can help in very quick, unexpected emergencies Split- such as hitting black ice at speed in a turn, someone not seeing you in their blind spot and violently cutting you off at highway speed etc. Even the best driver could use a hand at those times IMO. The best safety devices are the ones that prevent the accident in the first place!
Old 07-27-2009, 11:05 PM   #6
kkonaka
Drives: Yaris 3 dr 2009 Absolutely Red
(japanese) http://www.asahi.com/car/news/NGY200907270023.html
is saying totally new vitz(yaris) will go into production in late 2010 (2011 model year?) followed by a hybrid version a year later. - asahi is a major japanese newspaper; it may still be a rumor though.
kkonaka is offline   Reply With Quote
Old 07-28-2009, 06:55 AM   #7
Lewis
Lewis's Avatar
A hybrid Yaris (which I have read about too- the Prius gets pretty expensive for the fuel it saves) would likely get some impressive mileage- but what about the Yaris' price point- perhaps the thing it sells on the most?
Old 07-28-2009, 08:09 PM   #8
I just noticed that the 2010 Yaris info has been added to TIS. Here are the new car features for 2010:
1. Brake
The brake control system (ABS with EBD, Brake Assist, TRAC and VSC) has been newly provided; standard on all models for U.S.A. and optional on Canadian models (except Mexican package models).
2. Lighting
The daytime running light system has been discontinued on hatchback models for the U.S.A.
3. Meter
On hatchback models for the U.S.A., the slip indicator light is provided as standard.
On hatchback models for Canada, the slip indicator light, VSC OFF indicator light, and TRAC OFF
indicator light are available as an option.
On hatchback models (5-speed manual) for the U.S.A. and Puerto Rico, the combination meter with the tachometer is available as an option.
4. Enhancement of Product Appeal
A bracket has been provided on the frame of the lower-back area of front seats. In addition, the shape of the headrest used on some models has been changed.
5. Multiplex Communication
Components for the Controller Area Network (CAN) communication have been added. Along with the use of the VSC, the yaw rate and acceleration sensor and the steering sensor assembly have been added to CAN Controller Area Network) as communication components.
6. Cruise Control System
Since the brake control system (ABS with EBD, Brake Assist, TRAC and VSC) has been provided, a function that cancels the cruise control system at the time the VSC is activated has been added.
In the 2010 Model Lineup, the Manual Transmission is listed as a transaxle choice for the 5 door liftback, but it was for the 09 as well.
Old 07-29-2009, 12:14 AM   #9
uncleyaris
Cool info!
Old 07-29-2009, 08:59 AM   #10
markitect
Drives: Yaris
So does this mean the 2010 you will be stuck with traction control, and not be able to turn it off in the US (lack of an off light)? That sucks!!!
markitect is offline   Reply With Quote
Old 07-29-2009, 09:13 AM   #11
I am not sure if they mean that the VSC off switch will only be available on Canadian cars with the optional VSC or if it means that the switch and, hence light, will be on all cars with VSC. In the EWD for VSC it shows the VSC off switch with a note that says "w/VSC off Switch". Either way, looking at the EWD, adding the switch would be an easy mod.
Old 10-06-2009, 08:14 AM   #12
127.0.0.1
My new 2010 Yaris 5door door sticker says VSC and TRAC standard
the owners manual says where the VSC off switch would be -if equippped-.
I have no off switch anywhere...not near the handbrake area where it should be.
So, if I have it, I can't switch it off standard.
By the way...how could I add a switch ? I don't want to get stopped on a slippery slope
by the electronics.....is the info already in these forums ?
Old 10-06-2009, 08:57 AM   #13
Looking at the EWD for VSC on the 2010, I think that you will find that pin 30 is empty on your VSC ECU connector A30. It looks like that pin is grounded by the VSC off switch (on the non-US cars that have it). So, a quick and dirty test is to ground that pin and see if the Slip Off and Trac Off indicators light up.
Name:  Conn A30 - VSC ECU.jpg
Old 10-06-2009, 10:53 AM   #14
127.0.0.1
sweet. I got a little project box I will velcro inside the cubby below the
window washer stalk. In the project box I will put 4 spst for cruise control,
resistors, and a simple toggle switch for VSC, all prewired and everything.
then I will run the wires and 1) tap into the CC lines and 2) search for the VSC disable
and if it all goes good I will report me results
Old 10-06-2009, 09:34 PM   #15
tomato
tomato's Avatar
Hello, and welcome to the forum!
Old 10-07-2009, 09:08 AM   #16
127.0.0.1
cruise control project done. works mint. control box sits on floor till I wire VSC disable to it
and then it will be velcro'd somewhere.
Old 10-07-2009, 09:20 AM   #17
127.0.0.1
Ok call me stupid but where is the vsc ecu located ?
Old 10-07-2009, 12:07 PM   #18
On other Toyotas it is attached to the master cylinder. I haven't seen it on the Yaris yet, but would think that it is in the same place.
PINOUT info stereo ozmdd In Car Entertainment + Electronics (audio / video / alarm) 5 12-14-2009 07:52 AM
$1,600 Government Rebate on Fatt Batt Insulation or Solar Hot Water Systems Info. *MAD DOG* Australia 1 03-27-2009 09:44 AM
AutoX Info KS SOLO Tracking, Racing, Auto-X Forum 1 04-02-2007 04:45 PM
bi-xenon info Adriaan Cosmetic Modifications (Exterior/Interior) 0 02-05-2007 06:21 PM
car info uncleyaris General Yaris / Vitz Discussion 6 01-26-2007 05:13 PM
