Old 04-23-2009, 05:51 PM   #1
ozmdd
Reluctantly Crouched...
ozmdd's Avatar
Drives: 2008 Yaris HB M/T
PINOUT info stereo
I've switched my 08 Head unit for an 09 Scion pioneer unit (the basic version, not the "premium" Pioneer, and the AUX jack is no longer functioning. The pinout for the Scion is clearly different from the Toyota HU, but I can't find that info so I can change the wires in the plug behind the radio. Anyone have this info?
Old 04-23-2009, 06:44 PM   #2
how clearly different is it ? If speakers are operating properly and unit is powering up, it's the same wiring pinout. (toyota never changed its audio wiring since 1985)
if you can't pluging your aux port or you can't find what to push to activate the aux input, changes your HU does not have an aux port. A picture would help btw, because i still don't know which one you are talking about.
There should be an Aux button if aux is supported..
Old 04-23-2009, 07:16 PM   #3
Dave
Drives: 2007 Yaris Sedan
This should help.
Someone posted a DIY a while back (sorry, long day and I'm too lazy to search myself) on hooking the stock jack up to a new stereo, and found out that you don't need to wire the AUXO/I into the new unit. Left, Right, and Ground will do.
Good luck!
Dave is offline   Reply With Quote
Old 04-29-2009, 09:27 PM   #4
ozmdd
ozmdd's Avatar
Thanks. Its a Scion 09 HU with an AUX/ipod button, so I'm positive it is designed for the aux. Having read Scion forums, I see that Scion and Toyota stereos have different pin configurations for the factory aux plug-in. I'm hunting for a wrecked Scion to pilfer the console plugs from, so I'll have both the aux and the ipod port. If I don't find one, I'll rearrange the pins on the plug that goes into the back of the HU, since its the same plug, just different pinout. I'l post an update when its figured out.
Old 04-29-2009, 09:28 PM   #5
ozmdd
ozmdd's Avatar
IllusionX: T1808, Scion HU
Old 12-14-2009, 07:52 AM   #6
auxmike
auxmike's Avatar
Did you ever get this sorted out?
Blown Fuse - Stereo !?! click.mine In Car Entertainment + Electronics (audio / video / alarm) 16 10-05-2017 08:35 AM
Stereo Upgrades....what to do!? gravylegs In Car Entertainment + Electronics (audio / video / alarm) 39 02-28-2010 12:58 PM
Install sedan integrated stereo in hatchback? atebit In Car Entertainment + Electronics (audio / video / alarm) 6 05-22-2007 05:25 PM
ECU pinout ChinoCharles Performance Modifications 78 04-08-2007 06:10 PM
Stereo finished! Spades In Car Entertainment + Electronics (audio / video / alarm) 6 12-20-2006 10:17 PM
