#1 |
Steve88
Drives: Polar White 07 Sedan (S) Join Date: Dec 2008
Greetings Friends.
Well the anticipation is over. I popped my first fuse. Dunno how but for some reason there was some electricity left in my RCA cables coming from the stereo going to amp and .When I unplugged them (rca cables) from Amp in the trunk to tie them together, +/- touched, couple of sparks and next thing i know the stereo doesn't turn on. everything else seems to be find. weird i know. I didn't get a chance to look into it since it turns dark down here in san diego around 7:00 in march. Anyway, I know there are 3 fuse boxes in the car. So what I would love to find out is which one of the 3 fuseboxes I need to look into to see if the Stereo's fuse is blown & not being greedy but just wondering does any1 know which 1 is the 1 for the stereo. Thank you all. ![]()
Never Try, Never Fail !!! |
pull the fuse panel lid above drivers feet , all fuses are labeled on that.
#3 |
![]() ![]() ![]() ![]() Drives: '07 Yaris turbo, '11 Juke Join Date: Mar 2007
Check the fuse box under the dash on the driver's side. There is a diagram of the fuses on the cover.
http://www.cardomain.com/ride/3875996 |
#4 |
Steve88
Thanks for the quick responses. It's dark so I tried my best with a flashlight.
A. I took out the Glassholder plastic thingy and no diagrams on it. B. I removed the Plastic Piece all the way down where left foot rests. again nothing. C. Finally the fuse box in the engine, it has a diagram on the cover. In there, the only fuse sign that makes sense is the one that says RIO on it (30A). Is that the fuse I need to replace. I hope there's spare in there.
#5 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: '08 Bayou Blue LB AT Join Date: Oct 2008
Did you put your head on the floormat and look up here?
![]() It should look like this but without the wires I added.
aFe Intake | Blitz Supercharger | Megan Header | TRD Exhaust | NST Pulley Set TRD Shocks/Struts | Tanabe NF210 Springs | TRD Sway Bar | Motegi TRAKLITE wheels | Kuhmo Ecsta XS R1 Concepts slotted rotors | Carbotech 1521 brake pads | stainless steel brake lines | Seibon vented carbon fiber hood |
#6 |
Steve88
Dude ur Awesome.
Man I feel stupid. Allright, let me go check. I just hope the one for the stereo is in there. I just read like 5 manuals from the yaris repair manual page Thanks again. Here it goes
#7 |
I'm not sure but I think the radio is powered by the ACC fuse. Disregard the red ovals I added for another post.
#8 |
Steve88
Good News (Bad News) I found the fuse thanks to you all.
It's FUSE NUMBER 28 IN THE MANUAL (RED 7.5A). Guess i will be heading to kragen's or such to get the fuses.
#9 |
So, which one is fuse number 28? I lost my cover and fuse removal tool months ago.
#10 |
Audio Junky
when you go... if the store doesn't have 7.5amp fuses.... be sure to buy a lower value and NOT A HIGHER one. Fuses hardly ever pop unless there is actually a problem... so you don't want to risk a fire by going with a slightly bigger fuse.
(posting this more for anybody browsers who doesn't already know that than for those posting on this thread) |
#11 |
Steve88
Finally. Only Autozone had the package (7.5,10,15,20...) for like 3.50$.
no other place had these low profile fuses. I just hope other fuses are intact. THANKS AGAIN. next step: install dynamat on rear deck. whi...................
#12 |
![]() Drives: 2007 Toyota Yaris Sedan Join Date: Sep 2011
which one was fuse 28?
#13 |
![]() Drives: Yaris HB Join Date: Nov 2011
Lol i had teh same thing ....bought the car, the guy took out the audio thingys, and pfft radio wont work... im battling vs the fuses, thnx to this great post and teh pics found the fuse box, but now i cant tell wich one is the fuse...wich one is 28? Thnx and u saved my life, in Mexico there is virtually no way to find out stuff about the Yaris!
Edit..found another post that says its the 7.5A...so im guessing there is only one, ill find out in a while!. |
#14 |
Drives: toyota yaris 2007 hatchback Join Date: Jul 2014
toyota yaris 2007 stereo does not work dont know where is the fuse located
i tried to replace the stereo on toyota yaris 2007 and it was working at the begining untill i tried to connect some extra wires and then stereo stopped working ... maybe is the fuse ... anyone knows where i can find the fuse to fix this? is it located under the hood or next to the drive left leg ... can anyone send a picture so i could see wich fuse to change. thanks
#15 | |
#16 | |
![]() ![]() ![]() ![]() Drives: 2011 Scion tC Join Date: Jul 2012
![]() ![]() ![]() Traded my Yaris in for a tC and I sure as hell wasn't gonna give away my Pioneer AVX-2600 with GPS add-on. So I grabbed a cheap (although actually quiet nice) DUAL branded one from O'Reillys or possibly AutoZone, and swapped that in real quick. Blew the dome and radio fuse in the process because I was in a hurry, wheeee, sparks! but this thread and his post helped me fix that right away. ![]() Wanna laugh? The dealer actually offered me a job installing stereos for them because of the speed with which I produced such a nice looking result. I politely declined. If it was all Yarisses, standard radio openings, and color coded wiring, and not totally out of the way of both my office and my house, I might have considered it ;) TL;DR: stuff learned from Scott got me a job offer today. |
#17 |
Drives: toyota yaris 2012 Join Date: Oct 2017
audio control on the wheels
I have a toyota yaris 2012. the audio control buttons are n the driving wheels.
i have just changed the car battery and once the new battery was installed, the audio control buttons on the driving wheel stopped working. every thing else is working perfectly, though. could you help? |
| Stereo Upgrades....what to do!? | gravylegs | In Car Entertainment + Electronics (audio / video / alarm) | 39 | 02-28-2010 12:58 PM |
| I think blown fuse | BABY R | DIY / Maintenance / Service | 5 | 04-17-2009 01:45 PM |
| Winscreen fuse has blown twice | weebubbles | DIY / Maintenance / Service | 1 | 11-19-2008 11:39 AM |
| Install sedan integrated stereo in hatchback? | atebit | In Car Entertainment + Electronics (audio / video / alarm) | 6 | 05-22-2007 05:25 PM |
| Stereo Wiring question???????? | Yarisguy13 | DIY / Maintenance / Service | 4 | 05-13-2007 08:31 PM |
