Drives: toyota yaris 2005 Join Date: Feb 2010
TIMING TOOL FOR YARIS
MY YARIS IS OFF CYCLINDER 1&2 AFTER NEW VALVES INSTALLED,DO I NEED A SPECIAL TOOL FOR TIMING CHAIN. CAN THE CHAIN STRETCH
![]() ![]() ![]() Drives: Yaris Join Date: Apr 2009
I haven't been inside this motor but did you mark the position of the chain and sprocket(S) when you the cams. I am assuming that there are timing marks on bearing caps to the front and the cam base. Obviously, everything should line up at TDC so then it comes down to possibly having slack in the chain if not marked prior to removal.
| yaris timing belt | phenoyz | General Yaris / Vitz Discussion | 16 | 02-24-2015 01:05 AM |
| CAM TIMING | jt258 | Performance Modifications | 21 | 11-12-2009 12:50 PM |
| australian vs american models: timing chain | hoobyjuice | DIY / Maintenance / Service | 3 | 06-16-2009 09:25 AM |
| OBD2 scan tool to save fuel worth it? | ezhacker1 | Fuel Economy Forum | 11 | 05-08-2009 09:04 AM |
| Timing chain, sprockets, & cam position sensor problems? | PetersRedYaris | DIY / Maintenance / Service | 8 | 01-04-2007 11:50 AM |
