Old 06-15-2009, 10:17 PM   #1
hoobyjuice
Drives: Echo 2002 Hatch
australian vs american models: timing chain
Hi all,
I am wondering whether there'd be any difference in the engines between the Aussie and US versions of the 2002 Echo? Specifically, information for the US model says it uses a timing chain. Surely the aussie version would also have a timing chain (and not a belt)?
any info gratefully taken
cheers
christian
hoobyjuice is offline   Reply With Quote
Old 06-15-2009, 10:19 PM   #2
Tamago
Tamago's Avatar
Drives: UZJ100
if it has the same engine, it will have the same timing chain
Old 06-16-2009, 07:55 AM   #3
jambo101
jambo101's Avatar
Drives: yaris 08 sedan
My 01 and 05 Echo's have a 1.5l motor and both have timing chains.
Old 06-16-2009, 09:25 AM   #4
if you have the 1.5L 1nz-fe engine, yes timing chain.
others... well, i guess the 1.0L and 1.3L owners can tell us longer.
yaris timing belt phenoyz General Yaris / Vitz Discussion 16 02-24-2015 01:05 AM
wtf?! timing chain cover split?! jeff69dini DIY / Maintenance / Service 9 08-01-2007 12:11 PM
Does the Yaris' engine have a timing chain or belt? grampi General Yaris / Vitz Discussion 8 05-12-2007 03:59 AM
Timing chain, sprockets, & cam position sensor problems? PetersRedYaris DIY / Maintenance / Service 8 01-04-2007 11:50 AM
