![]() Drives: 1999 NHBP Honda Prelude Join Date: May 2010
Wiring diagram?
Hey guys I did a search and I couldn't find it.. I'm trying to find a wiring diagram for the 09 Yaris Sedan. I'm trying to install an alarm system with the Remote start. I bought my girl a Viper 5901 system and would like to install it! :] I'm new in electrical kinda.. but i do know the basics as well as some details....
We took the car to a shop named Promax located in Alhambra, Ca.. and they COMPLETELY failed on the install... when they installed it... when the unlock button is pressed it beeps 3 times instead of 2 times.. when you drive the LED on the transponder box thing keeps beeping...(It's supposed to not flash when you're driving)... When the lock button is pressed it beeps once.. like it's supposed to.. HOWEVER it says there is a door open.. ALSO there are no lights that flash when the buttons are pressed.. They said it can be a defective box.. however once they told me "you're LED's may be interfering with the brain.. It may be draining too much power" (the LED's are in the dome light and map light. replaced them because the stock lights were not bright enough.. besides LED's take out less power than regular bulbs) I have the Clifford 50.7x on my car (Honda prelude) and i have LED's everywhere.. and it works perfectly.. so the LED part fails.. So I really need your help guys.. I saw the Remote start diagram thing :] but i also need the alarm part :]. Thanks! |
#2 | |
![]() ![]() ![]() Drives: 2010 Meteorite Metallic LB Join Date: Feb 2010
One tip for you. The Viper 5901 comes pre programmed for a manual transmission so if you are installing it on a car with an automatic you have to re program it before it will remote start.
#4 | |
thanks for this tip! Where can i get it reprogrammed? Imma assume i should take it to an authorized viper dealer? |
If you are going to install it yourself you can reprogram it. The alarm comes with instructions on how to program it. If you don't want to do it yourself take it to a Viper dealer. We charge $130 for an alarm with remote start.
| ECU Wiring Diagram? | thebarber | DIY / Maintenance / Service | 16 | 05-22-2025 07:07 PM |
| Installing Trailer Light Harness | vandallen | DIY / Maintenance / Service | 7 | 06-10-2024 10:06 AM |
| Wiring Pictures | MitchEvious | In Car Entertainment + Electronics (audio / video / alarm) | 2 | 12-28-2009 11:43 AM |
| Wiring color code for 2008 LB? | charles nelson | DIY / Maintenance / Service | 0 | 04-25-2009 03:56 PM |
| NEED TPMS Wiring Diagram please | mikenacarato | DIY / Maintenance / Service | 9 | 02-11-2009 11:55 PM |
