Old 09-21-2009, 02:00 PM   #1
ECU Wiring Diagram?
anyone have the ecu diagram for an 07 yaris hatch? searched, but can't find it...
Old 09-21-2009, 02:12 PM   #2
BLH
Drives: 2007 Yaris Sedan
Closest I have seen is in section 5 of the EWD.PDF file part of the service manual. I downloaded from a thread here.
Old 09-21-2009, 02:46 PM   #3
http://www.etimago.com/yaris/repairmanual/
thanks to etimago for this one...
Old 09-21-2009, 11:35 PM   #4
Here's a chart that I put together. The connector pinouts are at the end of the EWD. I went through the EWDs to figure out every used pin on the two connectors.
In case you are wondering about the highlighting - They are the pins needed to fire up and ECM on the bench. The ones highlighted in red are the ones that need +12V and the yellows are the ones that need to be grounded.
Yaris ECM.pdf
Old 09-21-2009, 11:42 PM   #5
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
wow, very nice!!
Old 09-22-2009, 04:49 AM   #6
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Well done CTScott!
Much
Old 10-06-2010, 07:12 PM   #7
miketrd
Drives: yaris ts
Hellow all
I bought an 1nz-fet - NCP13 Vitz TRD engine with turbo from yahoo jpctrade auction.
By trying to put the motor on my car we found the following problem: The 2 sockets with wire from ecu to car speedometer are missing. I attach a photograph (111.jpg) to show the missing sockets.
So we found 2 sockets which match but we haven't the terminals of ecm (ecu pinout - wiring diagram) to construct the cables.
In addition to the above my car is Toyota Yaris TS 1.5- NCP13 2002 and the vitz trd engine is from a vitz rs turbo 2003 model (facelift). So the 2 harnesses are different.
I want to ask you someone have the pinout diagram for this or where could i find it?
Thanks in advance
miketrd is offline   Reply With Quote
Old 10-06-2010, 07:38 PM   #8
sleey0
Drives: 2008 Yaris LB
Goo luck finding that. Ouch.....
"And that goes for any of you, never get put down from someone who gets jealous of you; build it and prove them wrong. There will always be haters and naysayers but those are also the ones who's cars are worth less than my seats."
xbgod - 9/23/2010
sleey0 is offline   Reply With Quote
Old 10-06-2010, 10:17 PM   #9
Originally Posted by miketrd View Post
Hellow all
Thanks in advance
I think I have everything that you need. PM me your email address and I'll email you the pdf's.
Old 10-06-2010, 10:54 PM   #10
sleey0
CT just has every wring scheme imaginable!!!
You keep on surprising me:)
xbgod - 9/23/2010
Old 04-05-2015, 01:53 PM   #11
happyshadrack@gmail.com
Drives: echo
1nzfe engine pin-outs
CT please send me the same PDF. I have the same problem here with a new engine
happyshadrack@gmail.com is offline   Reply With Quote
Old 04-05-2015, 01:57 PM   #12
Drives: echo
Smile yaris ecu wiring pin-out
Hellow all
Thanks in advance
please forward me the pdf from CT if you can, bought a new enine with the same problem
Old 09-28-2015, 12:04 AM   #13
Kaws Wong
Drives: NCP10 Vitz 00
HI MAte,
I have the same problem also, would you please forward pdf diagram also?
Thank for your help.
BR.
Kaws
Kaws Wong is offline   Reply With Quote
Old 05-19-2018, 07:12 PM   #14
Juan Perez
Drives: Yaris ts
does anyone have the diagram?
Could tell me where i can find it
Just build a yaris TS with turbo and need the pinout diagram for the ECU vitz turbo (1nz-fet - NCP13 Vitz TRD)
thanks
Juan Perez is offline   Reply With Quote
Old 09-27-2019, 10:42 PM   #15
Sd2jza70
Drives: 2005 Scion xb
I’m in need of the diagram for the 1NZ-FET trd Turbo ecu if anybody would be so kind as to share it :)
Sd2jza70 is offline   Reply With Quote
Old 08-12-2022, 06:07 PM   #16
Huevito
Huevito's Avatar
In need of the diagram for the 1nz turbo also can someone help if anyone is still out there?
Huevito is offline   Reply With Quote
Old 05-22-2025, 08:07 PM   #17
Yousefzaid
Anybody knows which programmer use to program a 2023 yaris with a M [4A] blade key I'm need make replacement key
Yousefzaid is offline   Reply With Quote
ecu wiring, ecu wiring diagram, wiring
Installing Trailer Light Harness vandallen DIY / Maintenance / Service 7 06-10-2024 11:06 AM
FS: Motec M4 Standalone ECU w/ Ignition Expander Biggie™ Items for Sale by private party 6 10-20-2009 03:36 PM
Tricking the ECU to Relearn AF map gwasabi Performance Modifications 126 05-16-2009 07:15 PM
Wiring color code for 2008 LB? charles nelson DIY / Maintenance / Service 0 04-25-2009 04:56 PM
NEED TPMS Wiring Diagram please mikenacarato DIY / Maintenance / Service 9 02-12-2009 12:55 AM
