Old 05-12-2010, 12:35 AM   #1
RacerFreakXXX
JDM Fred
Drives: 06 Mazda Miata
Send a message via AIM to RacerFreakXXX
Rubbing Issues
Now I see plenty of complaints of rubbing and not rubbing. I'd like to find out if you were rubbing; where you were rubbing, what condition the roads are in where you live, what size wheel and tire you have, and also what suspension you are on and how low your drop is:
rubbing? - yes or no
where? - inside fender or on the lip
conditions of the roads? - smooth, full of bumps and potholes, in-between
wheel size? - ex: 15x7 +35 offset
tire size? - ex: 205/60
suspension? - trd struts & trd springs
drop? - 2"
It just seems like there is no clear answer and when it comes down to it, not everyone runs the same setup in the same conditions.
1990 Mazda Miata... I miss my Yaris
RacerFreakXXX is offline   Reply With Quote
Old 05-12-2010, 12:47 AM   #2
This is a great idea.
but with all due respect, there is no way you got a 2" drop from TRD springs.
Old 05-12-2010, 04:57 AM   #3
darkmoon87
darkmoon87's Avatar
Drives: 08 Yaris
Where? - both rears, tires rubbing against the upper area of the wheel well
conditions of the roads? - bumps here and there but nothing serious
wheel size - 17x7 with 40 offset
tire size - 215-40-17
suspension - 1.5" drop front + rear from spirit lowering springs and OEM shocks
experiencing lots of rubbing since I went from 205-40-17 tires to 215s
and on top of that, the oem shocks have become extremely bouncy, making things worse.
my car is going into a shop to install the tokico shocks this week.
RIP Yaris, I will miss your superb handling a lot.
darkmoon87's picture thread
http://www.yarisworld.com/forums/showthread.php?t=10013
darkmoon87 is offline   Reply With Quote
Old 05-12-2010, 03:37 PM   #4
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Wink
where? - lip (rear only)
conditions of the roads? - in-between
wheel size? - 16x7 + 37mm offset
tire size? - 195/50/16
suspension? - NF210 + 10mm rear spacers
drop? - 1.1" front 1.5 rear (guessing)
No more rubbing using spring stabilizers
This picture is BEFORE fix.
These pictures are AFTER fix.
CLA 250, 4MATIC
Old 05-12-2010, 06:43 PM   #5
Billiam
Drives: '10 White Yaris 4D LB
Should we include setups that aren't rubbing as well? Or should that be a seperate thread?
Old 05-12-2010, 07:50 PM   #6
RacerFreakXXX
JDM Fred
whatever you want, I figure this will be helpful for everyone. I edited it, so include if you are rubbing or not. Garm, for all you know there is someone who bought TRD springs and cut them, lol.
Old 05-12-2010, 08:09 PM   #7
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
vary nice.
Old 05-12-2010, 08:26 PM   #8
Billiam
This setup IS NOT rubbing on my car...though it may vary a bit from car to car.
'10 4 Door LB
TRD Springs (about 1.5 inch drop)
15x6 EM7 Rims, +39mm Offset
205/55 ContiExtremeContact
any rubbing issues with stock height and... severous01 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 03-15-2010 01:22 PM
anyone rubbing with df210 on 205/45/17 marcus Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 07-09-2009 10:59 AM
Rubbing botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 06-06-2009 03:32 PM
Df210 + Tokico Blues = Rubbing? detroiter Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 04-26-2009 05:30 AM
Rubbing: 185/60/15 w/NF210's songa Wheels, Tires and Suspension Forum sponsored by The Tire Rack 10 12-10-2008 05:09 PM
