Old 12-10-2008, 03:04 PM   #1
songa
Drives: 2009 Yaris Sedan (Black)
Rubbing: 185/60/15 w/NF210's
hey guys, just a quick question...if i am running on 15" rims with 185/60/15 size tires (same size as stock), and i have my sedan lowered with NF210's, will i get any rubbing? i heard that i probably wont, but my main concern is the OFFSET. i have a set of 15" wheels that have an offset of 38mm but im still a lil unclear as to what affect offset values have on rubbing. does anybody know if a 38mm offset with those wheels and tires and nf210's will cause rubbing on a sedan? any help apreciated, thanks!
songa is offline   Reply With Quote
Old 12-10-2008, 03:11 PM   #2
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
With that tire size you will be more than fine!
You might rub if you go wider ( 205's)
Go ahead...
Old 12-10-2008, 03:19 PM   #3
songa
THanks! just makin sure =)
Old 12-10-2008, 03:20 PM   #4
derickveliz2
derickveliz2's Avatar
Drives: Yaris Sedan "S"
Where in MA are you?
I have NF210 OEM wheels with 185/60/15 and 205/50/15 and no rubbing at all!
BTW it drives much better than stock
CLA 250, 4MATIC
Old 12-10-2008, 03:58 PM   #5
songa
nice thats some good info, thanks. im from the worcester area, but i work in cambridge, and im often in the allston/brighton area. i plan on doing NF210's on stock everything. i will probably get new rims but i plan on getting ones that are the exact same size as stock wheels. i do frequent some prety steep bumps tho..im hoping i can clear those easy =)
Old 12-10-2008, 04:08 PM   #6
derickveliz2
You'll be OK,
I work in Marlboro and Maynard we have projects all over the place, I go to Boston very often.
I have the S model you will be OK with the base model.
I can't tell you how much better ride I get with NF210s it's a complete new car, feels much better. and looks great
CLA 250, 4MATIC
Old 12-10-2008, 04:17 PM   #7
songa
cool, im not that worried then. have you ever considered installing the TRD sway bar as well? im really more after the looks than the performance but ihear so many good things about the sway bar and its not that expensive so i mite just have to try it out someday.
Old 12-10-2008, 04:22 PM   #8
derickveliz2
TRD Sway is in my wish list on 1st place! if you ever consider getting one, let me know and we'll split the shipping.
CLA 250, 4MATIC
Old 12-10-2008, 04:54 PM   #9
songa
its a deal! i havent thot about a timetable yet but i was thinking of doing a majority of these things in the spring once the bad weather and conditions are over with. in case you buy it before me, let me know when you plan on doing it, as I am flexible.
Old 12-10-2008, 05:02 PM   #10
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
my stock 15s dont rub with my df210s
Old 12-10-2008, 05:09 PM   #11
derickveliz2
Spring sounds good to me, we should pass the word to other Yaris owners in the area. We could save $ with a buy group.
CLA 250, 4MATIC
185/60/15 Potenza RE92 WMERCERECU77 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 11-18-2010 01:49 AM
Dealing With Rubbing nqd Wheels, Tires and Suspension Forum sponsored by The Tire Rack 42 04-24-2009 01:56 PM
Need Two Stock 15" Tires 185/60/15 With 70% Or More Tread The Architect Willing to Buy by private party 4 10-20-2008 09:22 PM
new rims, some rubbing, best fix? cali yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 22 06-04-2007 05:26 PM
