Old 06-02-2007, 12:58 AM   #1
new rims, some rubbing, best fix?
Got my new rims today, love them.
SportMax #002, 38mm offset, 16 x 7.
Tires are Falkens, 205/50/16
However, I'm getting some rubbing in the front (turns and bumps).
Should I go down to a 195 width tire? or will a height change (to 45 or even 40) make a difference? I don't want to change the rims.
Ideas?
Here's a front view. more pics under the "post your rims/tires" thread.
Old 06-02-2007, 01:31 AM   #2
Walter
Walter's Avatar
Drives: Polar White LB
Ideas?
Im running 16x7 with 205/40s at a 35mm offset with no rubbing issues at all! The tire size WILL fix your problem.
A nice car with wheel gap is like a unsightly panty line on a nice butt. Looks good, but would look even better with a thong!
Walter is offline   Reply With Quote
Old 06-02-2007, 01:40 AM   #3
Black Yaris
der Zeck
Black Yaris's Avatar
205/40R16's ar going to throw your speedo off quite a bit
Old 06-02-2007, 01:59 AM   #4
well, I don't care much what the speedo says... the tach is more important to me (install next week).
so it seems a 205 with a 40 height will fix my problem. Wonder if 45's would fix it also?
I'm going back to the tire shop tomorrow (America's tire), they have a great policy and will exchange the tires at no cost.
Old 06-02-2007, 06:19 AM   #5
Edd
Drives: None
You know, there is a reason that the speedo is the biggest gauge in the cluster...
Edd is offline   Reply With Quote
Old 06-02-2007, 09:02 AM   #6
kimona
kimona's Avatar
Drives: 2014 White VITZ
Well, I think this is what's happening:
Your tire (205/50/16) diameter is only 1.5% taller than stock, and it only fills the wheelwell by an additional 5mm. That's perfectly acceptable... provided you're running the proper wheel widths and offsets.
While a 7" +38mm wheel (with a 205/50/16) is only 3mm closer to your suspension, it unfortunately sticks out 17mm more than stock!
With the Yaris, a +38 mm wheel and a 205/50/16 pushes the wheel/tire package past the outer limits up front. The rear is just fine.
So, what can you do?
In Japan, the guys often run different offsets front and rear on the Yaris. That gnerally isn't an option for us here in the States because we have an extremely limited selection of wheels and offsets, and a one-size-fits-all mentality.
So, you could go with a higher offset wheel all 'round. Certainly, +38 is too low for the Yaris up front. We should probably be putting no less than a +42mm up front. Those few mm's absolutely make a difference!
If you love your wheels that much, then you can play with the tire size to compensate for the offset. Yes, you could probably solve your problem simply by running a narrower and shorter tire.
With a 195/50/16, you'll be shorter than the 205 you're currently running, but only 1mm shorter than stock. But, you'll be pushing the wheel/tire package out 5mm less than with the 205's.
So, 195's should solve your problem... provided you don't lower your car. If you do, then you may have to go with an even shorter tire.
Of course, 195's won't fill the wheel wells quite as nicely as the 205's, and when you start pushing the wheels out, the wheel gap starts looking bigger and goofier! The wheel gap doesn't look that bad when the whells are tucked.
Old 06-02-2007, 10:41 AM   #7
brickhardmeat
Lonesome Cowboy
brickhardmeat's Avatar
Drives: 2007 WHITE HATCHBACK
so what would happen if you applied some wheel spacers? you are saying the fronts are rubbing on the inside? this would set the wheel put a little further make it maybe a +33 with a 5mm wheel spacer, right? I'm surprised you are having problems really. I would have gone with 15's on 205/50/15, but that's just what I did. Are you on DF's?
SPONSORED BY
Old 06-02-2007, 11:33 AM   #8
Boo
Boo's Avatar
Drives: PW Yaris LB AT
I think he got rubbing outside, spacer doesn't help.
I bet 195 is your only option..
Boo is offline   Reply With Quote
Old 06-02-2007, 11:41 AM   #9
brickhardmeat
Lonesome Cowboy
yep, you are right if it's on the outside, maybe someone else mentioned the inside
SPONSORED BY
Old 06-02-2007, 12:14 PM   #10
Yes, the car is lowered. I"m sorry I forgot to state that before. Tanabe DF210 too, a full drop.
the rubbing is on the outside, and yes, I am pretty attached to these rims. The only other offset option for them is... +0 ! No way!
So, I'm off to the tire store to see what they have.
Old 06-02-2007, 12:43 PM   #11
grampi
Drives: Corolla
You could probably go with a 205/45 as well. That might give you enough clearance to stop the rubbing.
grampi is offline   Reply With Quote
Old 06-02-2007, 04:09 PM   #12
Thanks for the great feedback, everyone. We tried 205/40 and 205/45...but I ended up with some Kumho 195/50's that look just fine and I have no rubbing issues now. I give props to the guys at America's Tire, who spent the time with me today to get it right, and ended up refunding the difference for the slightly less expensive tires... thanks guys!
Whew.... on to the next mod..
Old 06-02-2007, 04:39 PM   #13
kimona
kimona's Avatar
Great! I bet the 195's look good on the car too; rather than sticking out a tad past the front fender like the 205's did, the 195's are probably more flush.
If you get a chance, please post a new front view photo like the one you started this thread with.
Old 06-02-2007, 10:23 PM   #14
ok, here you go, the new one, then the one that rubbed.
Seems like that bit of change in the sidewall did the trick:
195/50/16 Kumho ECSTA RSX:
205/50/16 Falken 512
Old 06-02-2007, 10:35 PM   #15
Walter
Walter's Avatar
I ran nine inch wide wheels in the rear of my old jetta. The way I pulled it off was with stretched tires and rolled (slightly pulled) fenders. This is very common in the VW community.
Old 06-03-2007, 05:00 PM   #16
kimona
kimona's Avatar
Hey, look at your photos closely.
If you look at the back of the front wheel well lip, you will see a significant difference with the 195's vs. the 205's.
And, if you look closely at the rims, you'll see more sidewall bulge on the 205's.
Old 06-04-2007, 12:40 PM   #17
grampi
Drives: Corolla
So let me see if it have the moral of this issue straight. If the front wheels have an offset of 42 or greater, running 205/50/16s should present no rubbing issues, and if your wheels have less than 42 offset, then you need to go with a 205/45 or 205/40 tire?
Old 06-04-2007, 12:54 PM   #18
brickhardmeat
Lonesome Cowboy
depends on the drop and the wheel width also
I would think +40 would have been ok but i have 15's, 16's with a 2 inch + drop and +40 might rub with the 205/50/16 but might be perfectly fine
blackyaris?
SPONSORED BY
FS Brand New Stock rims w/ Tires FlintS Items for Sale by private party 10 09-24-2007 08:22 PM
FS: 17'' Motegi MR7 Rims and Khumo Tires Sabretooth Items for Sale by private party 11 07-02-2007 02:55 PM
Need help when ordering my tires and rims thomasward00 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 04-26-2007 09:40 PM
FS: 07 yaris RS stock rims n tires thegame11 Items for Sale by private party 5 04-15-2007 01:25 PM
hufeisen rims JustYYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 01-17-2007 03:16 PM
