Old 06-19-2010, 07:57 PM   #1
marcus
toyota
marcus's Avatar
Drives: 2007 Yaris RS Blazed
Hid bi xenon problem need to keep drl due to fogs
Need ur help guys unfortunetely the single bulb no xenon I bought did cause flicker weird thing is we tried it on one side and it works no drl no flickering nut once I connected both of them that's when he'll got loose flickering when I start the engine I need to keep drl due to fogs also have hid on fogs too now how do I get this bi xenon to work and also keeping drl relay due to fogs. Thanks for the input guys
Old 06-19-2010, 08:17 PM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
just keep the relay, and disconnect the BLUE wire on from the DRL box..
Old 06-19-2010, 08:33 PM   #3
marcus
toyota
marcus's Avatar
And that will keep the fogs too I'll try that tomorrow thanks
Old 06-20-2010, 10:27 AM   #4
marcus
toyota
marcus's Avatar
can anyone confirm if i can just unplug the blue wire or does it have to be cut.. thanks
Old 06-20-2010, 12:01 PM   #5
marcus
toyota
marcus's Avatar
ok got it done by dicsonnecting the blue wire fr the drl relay..just a reminder for others..you dont have to cut it..just poke a mini flat screw driver to get the pin out for that blue wire.. no drl/no flicker. low and hi mechanical worked like a charm..
Can anyone confirm if we can relay hid on yaris with drl? marcus Cosmetic Modifications (Exterior/Interior) 0 06-10-2010 12:38 PM
Disabled drl and installed hids and now no fogs... 604yarisrs Cosmetic Modifications (Exterior/Interior) 10 02-14-2010 12:26 PM
HID flickering problem - DRL fog - Problem solved. IllusionX Cosmetic Modifications (Exterior/Interior) 9 10-01-2009 06:37 PM
xenon hid light bulb lilman717 Cosmetic Modifications (Exterior/Interior) 7 12-19-2008 08:07 PM
HELP!! HID problem 07yaris_fe General Yaris / Vitz Discussion 2 11-20-2006 06:00 AM
