Old 04-18-2009, 08:24 AM   #1
nimith
Drives: 2007 yaris hatch
HELP WITH BRAKE NOISE
My 2007 Yaris has 40,000 miles. I would say 75 percent highway. When I brake, no problem. After I release the brake, I get a pretty loud squeak from the rear driver side(USA). Any thoughts on this-Thanks!
nimith is offline   Reply With Quote
Old 04-18-2009, 09:29 AM   #2
ddongbap
Drums probably need to be cleaned out. Mine does this. But IDC.
Old 04-18-2009, 12:45 PM   #3
IllusionX
Drives: 07 Yaris Sedan Aero
mine does this as well.. no time to mess with it.
my front calipers are also stuck.. :(
Old 04-09-2011, 10:42 AM   #4
N9QGS
N9QGS's Avatar
Send a message via AIM to N9QGS Send a message via Yahoo to N9QGS
I am having maybe the same sound, and I am too wondering what it is... I posted a sound of the file at https://public.me.com/n9qgs click on brake.mov
I am open to suggestions... Its loud enough you hear it no matter how slow you release the brake and you can hear it within 10-15 feet easily of the car.
thanks, Ron
198K Miles
N9QGS is offline   Reply With Quote
Old 04-09-2011, 10:59 AM   #5
swidd
Drives: Yaris HB
Cleaning out the drum with brake cleaner spray, then lubricate with white lithium grease on the side of moving parts (NOT on the brake shoe surface itself), wont hurt anyway. The brake.mov sounds like just a dry spring or something less serious. Search on youtube for how to replace the shoe, or how to adjust star wheel. Just do the same routine without replacing the part. It is very easy.
edit: the shoe is likely touching against the backing plate behind your drums... put a dash of lithium grease right between where it touches (without getting any one the pad material itself). It is commonly done as part of installing shoes, thus the above suggestion that you focus your search on DIY drum brake maintenance.
Do not pay a dealership to fix this -- they may go off on a ghost hunt on your credit card.
Old 04-09-2011, 06:33 PM   #6
N9QGS
N9QGS's Avatar
thanks for the suggestion, I may look at this next week. Ron
198K Miles
DIY (sorta) - RunStop Rear disc brake conversion eTiMaGo DIY / Maintenance / Service 17 07-02-2019 09:24 AM
DIY INSTALL/REVIEW: Dezod X-Rated Yaris Brake Pads ChinoCharles DIY / Maintenance / Service 40 10-13-2017 06:23 PM
DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside YarisSedan DIY / Maintenance / Service 73 03-11-2017 07:05 PM
Dealer: Disabling the seat belt chime is now illegal? schleppy Cosmetic Modifications (Exterior/Interior) 13 04-18-2009 05:43 PM
DIY For radios that require attaching a wire to parking brake Slick DIY / Maintenance / Service 0 04-16-2009 09:14 PM
