#1 |
Drives: lil red 5-door Join Date: Sep 2006
DIY (sorta) - RunStop Rear disc brake conversion
Had this written up and lost in the hack, going from memory so might miss a couple steps
![]() Not really a DIY, but a documentation of the steps to install the RunStop rear disc brake conversion kit. It's really simple! 1) Obviously, get the car up on stands and remove the wheels. I don't have much pics at this point, but you then need to remove the 4 bolts that hold the wheel hub to the suspension, and remove the hub, as well as the drum brake plate. You also need to clamp shut the brake fluid line, as it will need to be disconnected (you can see this in the 3 photos below), and remove the handbrake line, as well as the plug for the wheel speed sensor (only if you have ABS, I believe) 2) With all that removed, your car should look like this: DSC00204.JPG 3) Now we reassemble, with the new brake bracket plate (note the small drum brake shoes on the inside, those are still used for the handbrake), followed by the wheel hub: DSC00206.JPG DSC00209.JPG This, by the way, is the stock drum brake plate: DSC00207.JPG 4) Now the fun part, the new discs and calipers! DSC00210.JPG First slip the disc over the lugs. To hold it in place for the next few steps, you can screw on just 2 of the lug nuts (if they don't screw in all the way you should find some kind of spacer, or just use a regular nut). 5) The caliper is then positioned and secured from the back side with the two black bolts provided (not shown, but you can see the holes through which they go in the next picture) 6) The pads are inserted, then held in place with the long black bolts, inserted from the back. Then, use the metal spring clips (not pictured) to hold the pads in place. DSC00212.JPG 7) Next we need to do the lines. The handbrake line, if I remember correctly, just screws back on at the back of the brake holding plate. For the brake calipers, the kit includes a new bendable metal line, which you must shape to fit, and connect back to the main brake line on the car chassis: DSC00214.JPG And that's preeetty much all there is to it... just repeat on the other side. Don't forget to take off the clamp, and bleed the brakes after installation. The results: _MG_1863.jpg Additional notes: Get your own kit from Micro Image! The rotors are 285mm if I recall correctly, so this requires a 15" wheel at the minimum. They do come with slotted discs (mine were prototypes so not slotted), and unpainted calipers (so you can paint them any color you want, if you want)
The price of freedom of religion, or of speech, or of the press, is that we must put up with a good deal of rubbish. - Robert Jackson ![]() Bye bye 1NZ... |
Parallel Parking Pro
You've got me wanting this rear disc conversion all over again.
Do Runstop sell this conversion kit without the caliper?
Leong's NCP91 Toyota Yaris E Hankook V12 Evo 195/55/15 on Buddy Club P1 replicas 15x7 ET +38 Stebel horns, Philips Silvervision turn indicator bulbs TTE Lowering Springs, Camber bolts TRD Blue brake pads Fujitsubo Super Wagolis axleback exhaust DC Sports header |
#3 |
If you get it from me, it's only offered as a complete kit. I do stock spare rotors and pads, by the way.
#4 |
Drives: 2012 Yaris RS Thai Spec Join Date: Feb 2012
eTiMaGo i'm in BKK and will be getting a Yaris 2012 RS next moth,
would like to talk about some of your mods and what i can do to my future ride, would def be interested in rear disk conversion and proper projector headlights. Any help would be appreciated. |
#5 |
![]() ![]() ![]() Drives: 2007 Yaris Hatch Join Date: Feb 2007
Aren't these conversion parts available from toyota?
#6 | |
Yes and no, you could certainly find a way to get the OEM parts from the Yaris that are equipped with rear discs, but if I understand, this requires a different version of the whole rear suspension beam!
#7 |
are u still 34/39?
Drives: flint mica yaris s sedan Join Date: Sep 2006
i want this kit, but where to buy?
#8 |
![]() ![]() ![]() ![]() ![]() Drives: red bare bone yaris hb 3dr Join Date: May 2009
microimageonline.com ask for garm or jeff
#9 |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 2009 Join Date: Sep 2010
It is no more available....:(( i wanted it too
Interior:ALL red, black roof Exterior:RTX scorpion painted GOLD, side and rear visor, oem spoiler, MI mesh grill, Hella supertone horn, RS badge, Vios badge, CF pillar, Led mirror cover, fog light HID 3000k, Projector retrofit HID 8000K Performance :MI CrankPulley, Tein springs, UR and TRD bar, TURBO IN PROGRESS Audio : Pionner DEH-80PRS, HAT L1V2, PowerBass 1100.5X 5 channel amp
#10 |
![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris Liftback S (RIP 07) Join Date: Apr 2007
this kit might not be available but there is also the KIDO kit if i remember correctly also on microimageonline.com
"It hurts more when its wet" |
#11 |
![]() Drives: 2010 Toyota Yaris Hatchback Join Date: May 2011
I found this on Wilwood's site for the combination caliper and parking brake. I was just wondering if it could some how be retrofitted to the Yaris rear brakes? http://www.wilwood.com/Search/PartNo...f=Rear%20brake
#12 |
![]() Drives: White 5spd Hatchback Join Date: May 2011
I am looking to buy this rear disc conversion and went to the website to order and it was not available can some one please help me???
#13 |
I have a couple on the way in an incoming ocean freight shipment. I think two kits.
#14 |
are u still 34/39?
#15 |
HacKers WanTed!
Drives: Yaris S HB & Yaris S SD Join Date: Aug 2007
Garm PM me on that rear conversion!
R-CaT Project Yar 2ZR |
#16 |
Drives: 2010 Toyota Yaris Join Date: Jul 2019
any kits available?
#17 |
2ZR swap. DO IT! Ask how!
Drives: 09 Meteoric Metallic HB Join Date: Feb 2011
Considering that the post by MicroImage is almost 6 years old and that they're no longer in business, I'm gonna go with no. The good news is that you can do this with OEM Yaris SE parts (rear axle, hubs, etc.), which may be available from a scrap yard.
| DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside | YarisSedan | DIY / Maintenance / Service | 73 | 03-11-2017 06:05 PM |
| ALL-NEW PRODUCT LINE: DISC ITALIA ROTORS and PADS | kargoboy | YarisUniverse | 11 | 01-20-2009 04:43 PM |
| Catback exhausts and rear disc brake conversions | eTiMaGo | Performance Modifications | 59 | 01-04-2009 06:13 PM |
| DIY: Painting Factory Brake Calipers | redyaris | DIY / Maintenance / Service | 38 | 05-26-2007 08:47 AM |
| Rear brake proportioning valve??? | PetersRedYaris | DIY / Maintenance / Service | 16 | 03-25-2007 11:10 PM |
