Old 09-04-2011, 03:04 PM   #1
SmartyPants
Drives: Yaris
oil filter change
My boyfriend put Mobil One synthetic oil in my '07 Yaris sedan.
He wants to know if he can remove and replace the oil filter without causing all the engine oil to spill out. Or if it all comes draining out when its removed.
Can someone answer this question?
Aloha,
SmartyPants
SmartyPants is offline   Reply With Quote
Old 09-04-2011, 03:36 PM   #2
RedRide
RedRide's Avatar
Yes you can just change an oil filter and the only oil that wiil come out is the oil contained in the filter.
This is done all the time.
In fact, you should not leave the same oil filter on for the extended life of the synthetic oil.
Old 09-05-2011, 12:19 AM   #3
SmartyPants
Drives: Yaris
thanks for the quick reply
at least Toyota thought about this when they engineered the car
Synthetic should be good for at least 15K but the oil filters probably 7.5K
So we will just change the filter at this point
Thank you!
Help with oil change specs autophile DIY / Maintenance / Service 31 04-25-2011 09:22 PM
Oil filter regal DIY / Maintenance / Service 12 10-05-2009 12:36 PM
Gear oil change choices (Canadians) Jem_hadar DIY / Maintenance / Service 17 08-29-2009 11:51 AM
Compiled 1NZFE Used Oil Analysis craigq DIY / Maintenance / Service 7 09-10-2007 04:27 PM
oil and oil filter question.. marcus DIY / Maintenance / Service 27 07-11-2007 03:25 PM
