Old 11-11-2011, 11:56 PM   #1
lk250f
Drives: Civic Si
Lowest coils for 3 dr?
Looking to get coils for a 3dr yaris. Its a 2008 and i want something that goes pretty low. I see most and the cars look low but not really tucking that well. I had the D2, megan and ksport in mind. Which go pretty low? Thank you in advance.
lk250f is offline   Reply With Quote
Old 11-12-2011, 06:13 AM   #2
rayy
Drives: sr
The d2's megans and ksport got very at the front its just the rears the way the cars designed it doesnt allow it to go mega low
rayy is offline   Reply With Quote
Old 11-12-2011, 09:37 AM   #3
lk250f
Drives: Civic Si
Gotcha, thanks for the response. Appreciate it!
Old 11-12-2011, 09:45 AM   #4
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
i got megans. I can get really low.. wheel tuck low.. but its for performance, not looks for me
-Derrick-
Old 11-12-2011, 09:32 PM   #5
03Z33
03Z33's Avatar
Drives: TCR10
Kido, Megan and Silkroad are lowest. Kido and Silkroad also include adjustable swaybar links which are very helpful when going super low.
Old 11-15-2011, 09:51 AM   #6
ljming99
Drives: Yaris '06
Im on Ksport coilover.
Only comment is that the front cant go low is due to the linkage which the coilover doesnt come with. So im looking for adjustable front links.
However the rear goes really really low, even with the springs push right up the the highest limits. however the main reason for this is partially contributed by the rear shocks design and the spring perch.
The rear spring preach design is not that good - so there is also a limit on how much you can extend the shocks, open too much and there is a risk that the springs dont sit properly on the pearch and might pop out if you hit a very bad pot hole or a bump real hard.
The length of the rear shocks cannot be extended to much as it also affects the rebound, i was experimenting with it and the rear was literally riding on the shocks with like zero rebound (lol)
That is my experience and what i found out so far for ksport, otherwise it is a pretty good setup once done up properly.
ljming99 is offline   Reply With Quote
Old 11-15-2011, 09:59 AM   #7
03Z33
03Z33's Avatar
Drives: TCR10
Micro Image have the adjustable swaybar links in custom lengths.
Old 11-15-2011, 09:09 PM   #8
ljming99
Drives: Yaris '06
Well....they should be somewhere on the plane enroute to me now
Old 11-16-2011, 02:24 AM   #9
03Z33
03Z33's Avatar
Drives: TCR10
Uprated Ignition Coils for 1NZFE Parmas Performance Modifications 38 08-08-2010 11:47 AM
Custom Turbokit 1nz Forced Induction Forum 58 10-09-2009 04:01 PM
did autolite spark plugs screw up coil or coils ?? la_scanner DIY / Maintenance / Service 20 04-09-2009 03:07 PM
For those that hammer the throttle, whats your average lowest mpgs? detroiter Fuel Economy Forum 65 02-07-2009 12:24 PM
Lowest Drop On Springs? Kaeon Wheels, Tires and Suspension Forum sponsored by The Tire Rack 33 08-20-2007 05:15 PM
