Old 05-30-2010, 05:28 AM   #1
Parmas
Parmas's Avatar
Drives: Vitz RS Turbo
Uprated Ignition Coils for 1NZFE
I am currently running my turbo 1NZFE with phased sequential injectors with a wastespark coilpack. Since this setup do not match full sequential operation I wish to know what direct ignition coils are available out there.
The only three I found are:
Okada Coils -
http://greddyvios.blogspot.com/2009/...or-1nz-fe.html
Splitfire coils -
http://www.rhdjapan.com/splitfire-di...-2nz-2az-54649
AEM coils -
Garm setup
Is there any other out there?
Another option is to add another coilpack and using 2 leads of each coil while the rest conclude to a wasted spark
Old 05-30-2010, 08:07 AM   #2
d1nzfe
Drives: 1NZ-FE
OBX
d1nzfe is offline   Reply With Quote
Old 06-01-2010, 08:57 AM   #3
Parmas
Parmas's Avatar
Do you know the price range of these OBXR? ^^
Old 06-01-2010, 11:05 AM   #4
d1nzfe
Drives: 1NZ-FE
$199 at ebay
Old 06-01-2010, 11:09 AM   #5
Parmas
Parmas's Avatar
do you have a link of them for specs?
Don't bother ..... after I read this .... http://www.thegalantcenter.net/showt...&highlight=obx
Old 06-01-2010, 11:41 AM   #6
Loren
What?
Loren's Avatar
Drives: 2007 Yaris LB
Why not use the OE Yaris coilpacks? Proper fit, reliable, available... what am I missing?
Old 06-01-2010, 11:49 AM   #7
Parmas
Parmas's Avatar
I am trying to get information on better coils than OE. Also I am not sure if they can keep up the charge at higher boost levels....
Old 06-01-2010, 01:02 PM   #8
Loren
What?
Loren's Avatar
I'm assuming you have full control over ignition events with your engine management. With that, I'd try the OE coils and see if they are sufficient. Coil-on-plug gives a pretty strong spark as it is, might be all you need.
(just hate to see the wheel reinvented until it's been proven to be an unusable wheel)
If that doesn't suffice, I'd look into whether there are any direct swappable Toyota coil units from a boosted Toyota. (assuming they aren't exactly the same parts) When it comes to stuff like this, you simply can't beat OE reliability. (not to mention availability and price)
Old 06-01-2010, 04:33 PM   #9
RHDVIPbB
Right beside you, wave
Drives: 08 PBM Yaris Sedan
It may be a long shot, but the 4b11 uses a similar setu as the Yaris. They have quite a few upgrades for the EVO so they may have one that will work for you.
Old 06-01-2010, 05:33 PM   #10
Parmas
Parmas's Avatar
I have full control over ignition ande you are right in saying to try with OE coils ... will discuss this with my tuner about it
Old 06-05-2010, 12:43 AM   #11
d1nzfe
Drives: 1NZ-FE
okada are good.
Old 06-05-2010, 03:06 AM   #12
yaris 2sz
www.yarisclub.gr
yaris 2sz's Avatar
Drives: yaris 1.3 2sz - 1.33 1nr
i think so. okada
yaris 2sz is offline   Reply With Quote
Old 06-05-2010, 07:35 AM   #13
06silveryaris
Drives: 2006 yaris
I can actually check on that today since I just bought myself a Lancer and will be selling my Yaris.
06silveryaris is offline   Reply With Quote
Old 06-05-2010, 09:37 AM   #14
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
If they can't spark at higher boost levels, the engine will misfire. If it doesn't misfire at maximum boost, you don't need uprated coils and will see no benefit from them. Spend your money on something else.
Old 06-05-2010, 11:48 AM   #15
Parmas
Parmas's Avatar
So I ask since now many are boosted..... can anyone post maximum boost achieved with stock coils ?
Old 06-06-2010, 01:01 AM   #16
scioncrew
scioncrew's Avatar
Drives: SCION tC
Send a message via AIM to scioncrew
not needed.. unless your going for big power. even then your going to need a CDI unit with the coils. put your money else were like tuning on the dyno.
05 Scion tC allmotor 350+ hp 9.34@144mph
05 Scion tC sfwd 880hp 9.96@147mph
05 Scion xB 280hp 12.97@104mph
07 Toyota Yaris 357hp 12.80@107mph
scioncrew is offline   Reply With Quote
Old 06-06-2010, 03:57 PM   #17
Parmas
Parmas's Avatar
You can share your information based on fact on what you said.....
Old 06-06-2010, 05:54 PM   #18
Yaris Hilton
Smile
Another option to consider is reducing the plug gap if you did experience misfiring under heavy boost. I doubt you can use enough boost with 10.5:1 compression to encounter firing problems. I think you might just find it won't go quite as far wider than normal as the plug wears before it begins to misfire as it will unboosted. But I don't run boost and don't plan to.
I have seen neglected plugs in unboosted engines grow some impressively wide gaps before starting to misfire. (Including my daughter's old Echo that came with standard plugs, no platinum or iridium, and went 107,000 miles.) The stock coils have a lot of extra voltage capacity with the plugs at stock specs.
FS: Motec M4 Standalone ECU w/ Ignition Expander Biggie™ Items for Sale by private party 6 10-20-2009 02:36 PM
Custom Turbokit 1nz Forced Induction Forum 58 10-09-2009 03:01 PM
Moving the Ignition To The Left? MadMax Cosmetic Modifications (Exterior/Interior) 4 10-02-2009 11:57 PM
Ignition locks? Blowtorch DIY / Maintenance / Service 4 05-13-2009 12:26 PM
