Old 10-02-2009, 08:30 AM   #1
MadMax
MadMax's Avatar
Moving the Ignition To The Left?
OK, this is for you big brains out there...
A lady I know has a Yaris sedan and due to physical limitations she has a hard time starting the car with the current location of the ignition. It would be considerably easier if the ignition could be moved to the left side of the steering wheel instead of the right, but is this even possible?
I don't know if she would be willing to do any major modifications to her Yaris but if this was possible she may just consider it. I just don't know if it is even feasible to move the ignition switch from one side of the steering wheel to the other. Does anyone know?
Cheers! M2
Old 10-02-2009, 10:24 AM   #2
yaris-me
Learn to Relax
Drives: 2007, Meteorite, LB
A new ignition switch can be placed somewhere on the left side, but the steering wheel lock is a different matter.
Old 10-02-2009, 09:55 PM   #3
PHXDEMON
PHXDEMON's Avatar
Drives: 2007 Red Liftback
Flip the whole steering assembly upside down
Old 10-02-2009, 10:22 PM   #4
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
I suppose you could remove the wheel lock, I have never tried though. It should be easy enough to get an aftermarket ignition cylinder to embed in the dash on the left
Old 10-02-2009, 11:57 PM   #5
Cosmonaut
The Last Baron
Cosmonaut's Avatar
Drives: 09 Polar White HB
would a push-start button work?
Sanction this outbreak, a Virus conspires. Single sparks are Spectral Fires!
| UR 19mm sway |
Cosmonaut is offline   Reply With Quote
FS: Motec M4 Standalone ECU w/ Ignition Expander Biggie™ Items for Sale by private party 6 10-20-2009 02:36 PM
Will local bay area members please stand up! YarisSedan California 264 07-28-2009 11:53 PM
2007 Yaris Sedan S Ignition won't turn koharegistrar1 DIY / Maintenance / Service 7 12-24-2008 08:34 AM
Ignition Issues kike DIY / Maintenance / Service 5 10-31-2008 01:43 AM
