Old 03-16-2012, 07:49 PM   #1
Zombie Yaris
Drives: 2009 Yaris Sedan
Need help wiring an aftermarket Radio
I just recently purchased an Pioneer AVH-P1400DVD head unit. The problem is I have no clue how to hook up the right cords. I have a 2009 Yaris S With twin 12 sub's hooked up in a ghetto fashion. Their spliced of the back deck subs then Jimmy rigged to hook to my amp. I bought this so that way i can run RCA cables form the amp right to the head unit for a much safer instillation. I need to have either the correct harness i could purchase off the internet, form like amazon or preferably a wiring guide. Really anyway to hook it up. Any help would be greatly appreciated.
Thanks,
Jordan
Zombie Yaris is offline   Reply With Quote
Old 03-16-2012, 09:08 PM   #2
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
best bet is to go to Crutchfield and use their guides or wizards.
http://www.crutchfield.com/m_760/Car...n.html?tp=1102
Old 03-16-2012, 10:01 PM   #3
TOLMACH
Drives: soarer
I bougth a harness like this one and each cable is marked .. so you just need need to connect the corresponding cables from your head unit's harness (acc to ass, positive to positive, negative to negative, remote to amp, etc.)
in case you want to use the internal implifiers of your head unit, you might want to run a separate 8-10 gauge positive and negative wires to the battery - you will need a basic wiring kit.. in case if only external amplifiers are used, do the harness and swith off the internal amps in hu setup
http://www.ebay.com/itm/METRA-2007-2...a0293a&vxp=mtr
Old 03-17-2012, 02:55 PM   #4
Zombie Yaris
Awesome! Thanks guys I'll see how it goes.
Old 03-17-2012, 03:02 PM   #5
Zombie Yaris
TOLMACH will that harness work for my specific radio?
Old 03-17-2012, 06:30 PM   #6
TOLMACH
Drives: soarer
That is harness for yaris 2006-2011 .. your head unit should come with its own harness (looks kinda similar with several cables of various colors) or just have a bunch of cables on its rear wall that need be connected to yaris harness. Please, check the manual for your head unit - it should include the wiring diagram where each cable is color-coded (like acc, remote, etc.)
if there is anything in the wiring diagram of your hu that you do not understand let us know
Old 03-17-2012, 06:40 PM   #7
TOLMACH
Drives: soarer
page 80 shows which wires must be connected to which wires of yaris harness
http://www.pioneerelectronics.com/St...nual021312.pdf
Old 03-17-2012, 07:17 PM   #8
Zombie Yaris
This is the harness they said to use. Will this one work as http://www.crutchfield.com/p_1207017...e-Harness.htmlwell?
Old 03-17-2012, 10:05 PM   #9
TOLMACH
Drives: soarer
looks similar to metra.. should work
Old 03-17-2012, 10:25 PM   #10
Zombie Yaris
Thanks a lot! I'll report here when I get my purchase in a few days to tell if it works.
radio wire colors & alarm wire color reference guide battleversiontc In Car Entertainment + Electronics (audio / video / alarm) 43 06-06-2023 02:12 PM
No AM radio signal on two aftermarket HUs? atebit In Car Entertainment + Electronics (audio / video / alarm) 21 10-08-2014 04:15 AM
Aftermarket wiring harness help yuriyaris615 In Car Entertainment + Electronics (audio / video / alarm) 1 05-18-2010 10:29 PM
Factory wire harness or plastic aftermarket piece for aftermarket radio????? Yarisguy13 Great Lakes 1 09-17-2007 10:14 AM
Toyota AUX plug w/ aftermarket radio? eight_heads In Car Entertainment + Electronics (audio / video / alarm) 20 09-07-2007 02:41 AM
