Old 04-19-2012, 03:46 AM   #1
calibretto123
Drives: 2009 Yaris LE 5-Door Hatch
Fully disassemble front emblem (09 Hatch)???
I realize that the issue of how to remove the front emblem has been dealt with many times, but does anyone know if it can be completely disassembled in order to do more finely detailed painting?
calibretto123 is offline   Reply With Quote
Old 04-19-2012, 04:35 AM   #2
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
Of course it can...but getting it back together may prove tricky.
-Type 07 FFL-
My odometer 03/11
Old 04-19-2012, 10:35 AM   #3
vadr45
vadr45
vadr45's Avatar
Drives: 2009 Base 3-door
Yes, of course it can, but there are holes behind it that would have to be covered. If you're serious, you also have to consider that even covering the holes leaves a large walled area on the front of the car that is anti-aerodynamic.
One idea might be to cut out the holed area behind and replace it with a mesh so that the air flow would cool the engine compartment, but I doubt it would look well...kinda like a single nostril... .
vadr45
Alexandria, VA
2009 Black Base 3-Door Yaris
1950 Austin A70 Hampshire
vadr45 is offline   Reply With Quote
Old 04-19-2012, 10:38 AM   #4
^ The emblem is two pieces, one chrome and one black. He is talking about the ability to seperate those two pieces in order to do some detail painting on it.
This thread has nothing to do with removing it from the car.
Old 04-19-2012, 10:51 AM   #5
spocksleftball
spocksleftball's Avatar
Drives: 2011 yaris
I tried but gave up. The back is plastic and the emblem is metal. They are glued together, and prying will bend the metal and mar the plastic. I sanded the metal by hand, primed and painted it as a unit. Worked good, but I was using flat black...not much can go wrong.
spocksleftball is offline   Reply With Quote
Old 04-19-2012, 02:14 PM   #6
OTA'sTOY
DAT'S RIGHT I GOTz 2
OTA'sTOY's Avatar
Drives: '10 5dr
^ time and patience i used a bunch of toothpicks, a razor blade and some wd40 (to remove the 3m sticky tape) that bonds the plastic chrome emblem to the black plastic backing
OTA'sTOY is offline   Reply With Quote
Old 04-19-2012, 06:32 PM   #7
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
What was your end result / goal for doing it?
Personally if I did black out badges I'd want to paint the chrome part black, then color match the plastic back part, and then stick it back together. (I think doing a black out of the front badge without disassembling it looks silly. You just end up with a black oval.)
Old 04-19-2012, 07:44 PM   #8
OTA'sTOY
OTA'sTOY's Avatar
Drives: '10 5dr
still in progress did a '10 xb front emblem base #75312-12350 covered with 3dwhite carbonfibre vinyl and a '10 tacoma #75311-04060 (blacked out)
just to see what kind of outcome alittle smaller than the yaris one
Old 04-20-2012, 12:27 AM   #9
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
Sounds like an interesting project! Pics when you're done?
Old 04-20-2012, 06:16 AM   #10
spocksleftball
Drives: 2011 yaris
Yeah, thanks for being judgemental. Btw, my yaris is black, blacked out badge...and it doesnt look silly. Anyway, I was simply relating my experience to the op.
Old 04-20-2012, 09:00 AM   #11
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
I wasn't being judgmental, as black on black on a black car is still going to be black. I wasn't actually referring to you at all in my post.
I don't mind blacked out emblems on black cars one bit. If I had a black car, I'd consider doing it myself. But, I don't...
What I was saying is that if you have a say a silver car, pry apart the front badge so your it looks the same as the back... like so..
Old 04-20-2012, 05:53 PM   #12
calibretto123
Right on, guys, thanks for the quick responses.
Old 04-20-2012, 07:07 PM   #13
mazilla
advocatus diaboli
mazilla's Avatar
Aside from my joke above, I think I did take my emblem apart once. I recall doing a bunch of work so I could have the black plastic background against the gloss black I was planning on using. I got it all done and when I put it back together I smudged it or something so I just re-blasted the entire thing one color. IIRC I had to dremel some plastic studs or something...
-Type 07 FFL-
My odometer 03/11
vitz front emblem jesse1000 Canada 15 08-30-2010 12:31 PM
for sale - yaris hatch front bumper (slight damage) jesse1000 Canada 4 12-06-2008 09:03 AM
Sedan Front Emblem id3379 Cosmetic Modifications (Exterior/Interior) 5 11-02-2008 01:44 AM
Rear VITZ Emblem & Hatch Opener Painted Polar White. [pics] Chris07LB Cosmetic Modifications (Exterior/Interior) 39 05-04-2007 05:20 PM
Color-Matched Front Emblem [pics] Chris07LB Cosmetic Modifications (Exterior/Interior) 22 09-09-2006 04:22 PM
