![]() ![]() Drives: Yaris RS 2007 Join Date: Oct 2006
Door Handle LED DIY with pics
Finally I have time to take some pics of the DIY. Since my english is very poor, I will use pics instead of speaking. Hope this will help and feel free to ask questions and add comments.
I am having a 5 Dr yaris, so I will start with the front door and you can get the LEDs from Walmart for $10 (4 of them) 1. open the front door and locate the black stuff which cover the screw and remove it ![]() 2. unscrew the screw (the screw has something to hold on to it, so no worry it will fall into the door) ![]() 3. after you unscrew it, remove the lock and the handle ![]() slide the handle toward the back of the car and remove it ![]() 4. drill a hole in the handle and put your LED in it (I used hot glue to keep the LED in place) ![]() 5. run the wire in the door and through the wire tube into the car ![]() Now come to the rear door 6. For the rear door, we have to remove the lock in order to get to the screw, so we have to remove the door panel and there are only two screw for the door panel. ![]() ![]() 7. remove the cable for the lock and unplug any wire for the power window or whatever u have. ![]() ![]() ![]() 8. after remove the door panel, u can unplug the wire and remove the lock ![]() ![]() 9. u will be able to see the screw after u remove the lock ![]() 10. remove the door handle the same way u do for the front door ![]() ![]() again run the LED wire through the wire tube into the car Now u can connect your LED wherever u want. I run the wire to the keyless dome light circuit, so when i open the door, this will come on Hope u guys like it
| DIY Rear Drum Brake Adjustment/Parking Brake W/ PICS Inside | YarisSedan | DIY / Maintenance / Service | 73 | 03-11-2017 07:05 PM |
| DIY (08' USDM LB): Interior Light Color Change | revnull | DIY / Maintenance / Service | 37 | 05-21-2016 01:59 PM |
| DIY: Yaris LB Halo Led Projector Headlights | goku87 | DIY / Maintenance / Service | 37 | 11-15-2013 07:23 AM |
| DIY: LED side mirror installation | eTiMaGo | DIY / Maintenance / Service | 85 | 06-24-2011 12:48 PM |
