Old 08-10-2012, 09:50 AM   #1
azeeroth
Drives: '09 Yaris
09 Stock HU - front and rear AUX in?
I have a 2009 Yaris YRS with the stock HU that has the Aux port on the bottom right (Australian here). I'm running a CarPC and plugging it into that port at the front but want to move the cable to the back.
Is there wiring on the back that I can rig to accept an aux in?
If there is and I do that, is there a way to have the front port override it if my missus plugs her iphone into it?
So two aux inputs, one back and one front. Front one overrides. Sounds simple right?
It's this stereo even though this is a YRX
azeeroth is offline   Reply With Quote
Old 08-10-2012, 10:37 AM   #2
PatrickJohnson
Drives: 2008 Yaris LB
You can open the radio and tap into that AUX jack, but I don't think you'll be able to override with a plug. A jack can only do so much. You probably could do it if you did some PIC or Arduino programming but it would we WAY too complicated (IMHO)
You could quite easily wire it in with a toggle switch though which would allow you to select front or back jack. That would be pretty easy to do.
PatrickJohnson is offline   Reply With Quote
lowering spring specs for Yaris botchilah Wheels, Tires and Suspension Forum sponsored by The Tire Rack 20 03-22-2017 08:47 AM
Get your post counts here! *read 1st post for rules* Astroman Off-topic / Other Cars / Everything else Discussions 3414 11-04-2012 09:03 AM
2012 Nissan Versa Kal-El Off-topic / Other Cars / Everything else Discussions 22 06-15-2012 04:48 PM
Newly refreshed 2011 Toyota Corolla Kal-El Off-topic / Other Cars / Everything else Discussions 23 11-27-2010 12:57 PM
WTB: Stock front and rear struts heeroyuy01195 Willing to Buy by private party 4 06-15-2009 12:02 AM
