Old 02-09-2013, 11:44 AM   #1
Captain Slow
My Face Is Ridiculous
Captain Slow's Avatar
Drives: 2010 Toyota Yaris 3dr LB
Longer wheel studs for 5mm spacer?
Thinking about getting some 5mm wheel spacers all around, just curious what the consensus around here is regarding longer wheel studs being necessary or not with a 5mm spacer. I take corners hard as hell and wouldn't want a wheel coming off, lol.
I'm also assuming that for something as small as 5mm any cheap amazon or ebay pair would do the trick (obviously if I was going bigger I'd get something from a good company).
Thoughts?
Captain Slow is offline   Reply With Quote
Old 02-09-2013, 11:50 AM   #2
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
up to ~5-7 should be fine
measure the opening of the lug nut and measure about how deep the stud is threading into the lug nut, if these numbers are pretty close then you're fine.
Do a google search and youll see a lot of similar consensus. I ran 3mm without issue
Old 02-09-2013, 01:08 PM   #3
Captain Slow
Cool, I found some decent looking 5mm spacers with the correct 54.1mm hub on eBay for $26
Old 02-09-2013, 01:17 PM   #4
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
I put 5mm spacers on front and rear so that the front wheels would clear the brake calipers, and installed longer studs just to play it safe. Micro Image sells nice sets of them.
Old 02-09-2013, 09:54 PM   #5
NJ Drive
Drives: 2012 Yaris SE
A rule of thumb for minimum thread engagement should at least equal the width of the bolt/stud. So for a 12mm x 1.5 stud, use at least 8 turns of rotation. Tire Rack recommends 6.5 at minimum, but I always err on the side of safety.
NJ Drive is offline   Reply With Quote
Old 02-09-2013, 10:12 PM   #6
I have 5mm spacers all around, and I wouldn't get anything thicker without getting longer studs. I think my lug nuts only catch about 3 threads of the studs. I check the torque on them about once a week due to this.
Old 02-09-2013, 10:14 PM   #7
1.5
Form>Function
1.5's Avatar
Nice sig ^
Old 02-09-2013, 10:35 PM   #8
Nice sig ^
Thanks
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
FS: Sparco Wheel, Quick Release, Momo Spacer Focus_Sh1ft Items for Sale by private party 18 04-27-2011 12:36 AM
anyone knows if wheel spacer can be placed behind the hub??? jackrabbit Wheels, Tires and Suspension Forum sponsored by The Tire Rack 3 07-02-2010 06:41 PM
Wheel Spacer Help/?'s Please... bdc87 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 06-04-2009 07:40 PM
