Old 06-03-2009, 10:19 PM   #1
bdc87
HISTORY REPEATED 11/04/08
bdc87's Avatar
Drives: 07' MM Vitz LB
Send a message via AIM to bdc87
Wheel Spacer Help/?'s Please...
I might sound like a complete idiot on this thread and maybe I am when it comes to the round things that make are cars roll but here we go..
I'm currently in the process of refinishing some early mazda miata wheels, 14/5.5 +45. I'll be using a 175/65/14 tire. And to get these on in the front I'm going to need some spacers, as they rub the caliper, I'm thinking of 5 or 10mm leaning towards the 5mm. First off is this possible with this offset? Second, with the 5mm will I need to install extended studs? 3rd, is Ichiba a good brand? And lastly will a 5mm look ok with 10mm Penguin Rears?
bdc87 is offline   Reply With Quote
Old 06-03-2009, 10:24 PM   #2
Don't buy Ichiba. Buy Penguin for the rear and H&R for the front (since they make a 5mm version).
5mm front / 10mm rear will look just fine.
5mm front will give you an effective +40 in the front, which is fine with your 175 series tires.
Old 06-03-2009, 10:35 PM   #3
bdc87
bdc87's Avatar
Do you offer the 5mm? If not who does for a good price?
Old 06-04-2009, 01:21 PM   #4
Nagoya_TRD.
Drives: None.
What is wrong with Ichiba? Just curious, i have never used them.
I have had great luck with Project Kics.
Nagoya_TRD. is offline   Reply With Quote
Old 06-04-2009, 05:14 PM   #5
bdc87
bdc87's Avatar
That would be my question too but, I'm finding H&R's at only $10 more then the Ichiba.
Old 06-04-2009, 07:40 PM   #6
CASTREX
Who said Yaris was slow?
CASTREX's Avatar
Drives: Yaris T-Sport 2008
Go for the 13mm Pinguin on the back and 10mm H&R's up front.
With such skiny wheels you WON'T have a problem... You could even go a little wider if you would like. And you car will benefit from the wider stance...
... 175 tires?? Are you an hypermiler?? Go for a 185/60 tire.
Official YARIS Wheel & Tire Guide Black Yaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 403 08-09-2025 11:20 PM
The Yaris Steering Wheel wornways General Yaris / Vitz Discussion 12 10-09-2012 01:41 PM
Steering Wheel Issue. Twistoffate0817 General Yaris / Vitz Discussion 8 01-31-2009 07:38 PM
Toyota Throttle Body Spacer: the Best Fuel-Saving Device davidmills Performance Modifications 1 07-01-2007 11:38 PM
