Old 01-30-2009, 07:41 PM   #1
Twistoffate0817
My Little Blue Egg :)
Twistoffate0817's Avatar
Drives: '09 3 door Yaris
Steering Wheel Issue.
Hello, Everyday when i let my car sit (and it only happens in the afternoons, NOT in the mornings) the wheel feels extremely loose, and just like i really dont know how to explain it. Like when i go to turn the wheel, it feels like its loose and like very light.
Heres my story: So i would get in my yaris in mornings around 8 am, everythings fine...i get to work and park, and it sits until 4 pm. When i go to use the steering wheel at 4 pm to come home, the steering wheel just feels loose and almost as if i was turning the wheel with it not attatched to anything! But this feeling of it being loose goes away after 5/10 minutes of driving.
I was just wondering if anyone else has had this "feeling" happen to them, and if it sounds normal, or should i have it checked out.
Im sorry i couldnt explain it better!
Twistoffate0817 is offline   Reply With Quote
Old 01-30-2009, 07:43 PM   #2
twowheels
Drives: '09 Meteorite Metallic 3 dr MT
I seem to remember a statement in the Factory Service Manual or the Owner's Manual that stated that if there was a problem with communications with the electronic power steering ECU that it'd be a bit easier to turn in some cases, though I think it was easier to turn at freeway speeds and harder to turn at low speed, so maybe that's not your problem.
twowheels is offline   Reply With Quote
Old 01-30-2009, 07:46 PM   #3
Twistoffate0817
Yeah thats not my problem, and this is an everyday issue.
But thanks!
Old 01-30-2009, 08:03 PM   #4
ddongbap
I thought it was super easy when you're at a super low speed. Then it stiffens up when you're going faster.
Old 01-30-2009, 08:04 PM   #5
tk-421
tk-421's Avatar
Drives: 5D-07-LB
^^ Exactly. The wheel will tighten up the faster you go.
Old 01-30-2009, 08:52 PM   #6
Bob_VT
Bob_VT's Avatar
Drives: 08 Yaris LB
If you suspect a problem..... ask the dealer to check the steering. Nothing is perfect and something may be going wrong...... you have a warranty
Old 01-30-2009, 11:59 PM   #7
k2vitz
k2vitz's Avatar
Drives: Vitz 2006
Yaris steering wheel is speed sensitive i.e. at low speed will move freely and at higher speed will get stiff. In your case it seems like this, so nothing to worry. Otherwise get it checked by the dealer.
k2vitz is offline   Reply With Quote
Old 01-31-2009, 09:31 AM   #8
ya... plus, the fully electric powersteering helps too..
i remember when i did my window tinting at a guy's garage, we had to push the car around the garage so another car could get in, we let the key in the ignition at ACC ON because he had to roll up and down the windows. That's when i found out it was so damn easy to turn the steering wheel :P
anyways... it's warmer in the afternoon, and everything moves more freely when warm. That's why you don't get this feeling when you drive it in the morning. Anyhow, if you believe there really is something wrong, bring it to the dealer.
Old 01-31-2009, 07:38 PM   #9
*MAD DOG*
*MAD DOG*'s Avatar
Take to dealer.
Mesh Steering Wheel Cover... Toxic? IsLNdbOi Cosmetic Modifications (Exterior/Interior) 20 07-03-2010 05:53 AM
Works bell/Nardi quick release steering wheel setup blacksandiegovitz Cosmetic Modifications (Exterior/Interior) 35 09-02-2009 05:52 PM
OEM foglight switch and leather wrap steering wheel 808yarisLB Cosmetic Modifications (Exterior/Interior) 8 03-11-2009 12:05 AM
SCION SPORT STEERING WHEEL, RED, XA AND XB, 03 TO 06 justoneyaris Items for Sale by private party 3 12-04-2008 06:30 PM
steering wheel setup aucorium Cosmetic Modifications (Exterior/Interior) 0 07-24-2007 01:05 AM
