Old 07-25-2009, 12:10 PM   #1
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Low RPM when Idle
I'm sorry if this is in the wrong section, I don't know what to class this under.. it's more like a general inquiry. Anyway, when I put my car into neutral, the rpms drop LOW. Like, 600 low. Is that normal for an '06 Yaris?
Old 07-25-2009, 12:16 PM   #2
SilverBack
Joey
SilverBack's Avatar
Drives: '14 Scion xD 5-speed
That's normal for any car
Old 07-25-2009, 01:50 PM   #3
Altitude
Altitude's Avatar
Drives: '08 LB MT Bayou
Yup, it's called "idle".
Old 07-25-2009, 02:29 PM   #4
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
From the 2007 Engine Mechanical Repair Manual
(5) Inspect the engine idling speed.
Idling speed:
550 to 650 rpm for manual transaxle
650 to 750 rpm for automatic transaxle
NOTICE:
• Turn all the electrical systems and the A/C off.
• Inspect the idling speed with the cooling fan off.
• When checking the idling speed, shift the transmission to either the neutral position or the parking position.
Old 07-25-2009, 03:59 PM   #5
PhilD424
Drives: Red Yaris
The idle should never change on any car controlled by the computer. The computer has a set idle that is programmed in and can only be changed by engine diag software through a computer. If your idle is to high or low then theres something wrong with a sensor such as the TPS or MAS.
-Phil
PhilD424 is offline   Reply With Quote
Old 07-25-2009, 07:04 PM   #6
Yaris Hilton
Half a Bubble Off Plumb
Yaris Hilton's Avatar
Drives: 2009 Yaris Sedan
Smile
The ECU actually learns how the engine runs best as it gets a bit of mileage and running time on it. Mine started out idling around 700, and now settles in a hair over 600.
Old 11-01-2011, 08:29 AM   #7
charlieXX
Corporate Slave
charlieXX's Avatar
Drives: 2010 Yaris YX aka "Cutie"
On this low idle situation, does your engine feel like wobbling or vibrating not too much though but there is a vibration compared to 800-900rpm which is smooth?
Si Vis Pacem Parabellum
CharlieXX: Independent Pinoy Yaris Owner in Riyadh...... Not connected to any organization and don't NEED to.
Keep your ride rockin and rollin
charlieXX is offline   Reply With Quote
Old 11-01-2011, 09:31 AM   #8
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
yes, I am curious also what your Idle is 2 years later... lol
-Derrick-
Old 11-02-2011, 10:39 PM   #9
Betrivent
Not quite a noob
Betrivent's Avatar
Drives: e46 325
Wow.. hehe thread resurrection! So after driving two years since learning manual (I was new to it when I got the car) RPMs have remained at 600 give or take.
Old 06-14-2012, 03:48 PM   #10
jp_costarica
Drives: Yaris sedan 2007
My yaris 07, after warm up, set RPM at 400-500, no problem with that...! : )
jp_costarica is offline   Reply With Quote
Old 12-17-2012, 01:08 PM   #11
dindy
metallic green vitos
Drives: 2002 toyota vitz. 1.0 auto
Send a message via MSN to dindy
haynes says, about 600 - 750 auto and 550 to 650 manual.
dindy is offline   Reply With Quote
Old 03-03-2013, 01:27 PM   #12
esse10
Drives: 2009 yaris 2 door
Idle too low
Mine is also about 600 at Idle and too low in my opinion. Most manual tranny cars should have an idle of 800-900 rpm. Does anybody know of how to increase the idle rpm without having to visit the dealer and their expensive fancy Computers.. ???
esse10 is offline   Reply With Quote
Old 03-03-2013, 07:55 PM   #13
why?
Only Happy When it Rains
why?'s Avatar
Drives: Yaris LB
that is total bs. I know you are long gone, but for anyone still reading, many cars idles are very much mechanical, not computer controlled. Not sure if the stock Yaris is mechanical or not. I'd love to know though.
If it is mechanical you could set it higher. If not you cannot. The Yaris comes from the factory to save as much gas as possible. An extremely low idle helps.
Colin Chapman disciple
DIY - 1.8L 1ZZ-FE TB Connector Chip Swap Yaris T-Sport DIY / Maintenance / Service 332 04-03-2022 02:39 AM
Source code for Yaris Tachometer metalshark DIY / Maintenance / Service 27 04-06-2009 01:41 AM
Best MOD for midrange to lower rpm gain. Neen a little more low end grunt. dtbrown Performance Modifications 13 03-29-2009 05:35 PM
Help with low idle from Venezuela Yarisvene DIY / Maintenance / Service 5 06-23-2007 09:23 AM
Low idle speed gonzo452001 DIY / Maintenance / Service 9 02-21-2007 09:41 PM
