Old 03-08-2009, 04:45 AM   #1
Yaris T-Sport
Nov 2006
Drives: Vitz S1600
Cold Air Induction|Blitz SUS POWER Air Cleaner System|2.4L 2AZ-FE Throttle Body|Blitz Compressor System|Full Light weight pulley kit|GReddy Ti-C exhaust System|Blitz Throttle Controller|T/B Coolant Bypass + Gasket Trimmed|Weight deduction|Exhaust Manifold|Center pipe|PCV Bypassed
Yaris T-Sport is offline   Reply With Quote
Old 03-08-2009, 04:51 AM   #2
wow excellent idea!
Old 03-08-2009, 04:58 AM   #3
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Awesome info! Thanks
Old 03-08-2009, 08:31 AM   #4
WolfWings
WolfWings's Avatar
This bit of info let me dredge up something that might explain why earlier folks had fewer issues with the throttle-body swap.
Some Corolla's came with throttle bodies with ID #22041 on the chip housing. Others have that problematic chip-housing with ID #0D031. What'cha wanna bet the #22041 chip is special in some way? :-)
Old 03-08-2009, 05:52 PM   #5
yarstar
Drives: 2008 Absolute Red HB
DUDE YOU ROCK!!!
Thank you for solving this issue for us. I can now finally install mine without a CEL coming on.
Does this also solve the high rpm when cold problem?
This is great. I am so stoked to get this on the car. It truly makes a difference that can be felt.
AEM CAI, NST Pulleys/SSK, WR 4-2-1 Header, TRD axelback, R1 Concept Rotors, TRD Sway Bar, Nitto Rear Strut Bar, Cusco GT-Zero Coilovers, 1ZZ-FE 1.8L TB
yarstar is offline   Reply With Quote
Old 03-08-2009, 06:20 PM   #6
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Do I need to drill through the bolts in order to crack open the TBs? Is there a better/safer way to accomplish this?
Also, what is the best way to trim the intake tube to fit the new diameter?
Old 03-08-2009, 06:35 PM   #7
AlexNet0
AlexNet0's Avatar
Drives: '07 Yaris 3dr
I believe they are riveted, so you will most likely have to drill them out. or be really careful prying them out
Edit, nevermind, he beat me to it.
Old 03-08-2009, 10:16 PM   #8
yarstar
Cool. I'll take the high rpm at cold idle if we can get rid of the CEL.
Thanks again T-Sport. This made my day.
Old 03-08-2009, 10:20 PM   #9
AlexNet0
AlexNet0's Avatar
mind if i make this a pdf for sticky posting if the mods want it?
Old 03-08-2009, 11:41 PM   #10
Arkhangel
Arkhangel's Avatar
Drives: 2007 Yaris Sedan
ok so bigger TB means more air coming in? What is the performance gain with it?
Good? i have stock intake with K&N Drop in filter, do i need to change my intake?
The difference between fiction and reality? Fiction has to make sense. --Tom Clancy
Arkhangel is offline   Reply With Quote
Old 03-09-2009, 12:23 AM   #11
mikenacarato
SIPNDEW
mikenacarato's Avatar
Drives: 15 STI
can anyone confirm after driving over 100 miles that no cel comes on?
BTW this thread is awesome! thanks for doing this!
Old 03-09-2009, 01:18 AM   #12
gwasabi
Drives: 07 Blazing Blue LB
no CEL over 100 MPH
gwasabi is offline   Reply With Quote
Old 03-09-2009, 02:00 AM   #13
LtNoogie
LtNoogie's Avatar
Drives: '08 Bayou Blue LB AT
Good work on figuring this out. Where did you get a 1zz tb? At a junkyard?
Old 03-09-2009, 02:28 AM   #14
PETERPOOP
PETERPOOP's Avatar
Drives: 08 white liftback
this it?
http://cgi.ebay.com/ebaymotors/TOYOT...Q5fAccessories
Old 03-09-2009, 04:38 AM   #15
FunctionSpec
Super Newbie
FunctionSpec's Avatar
Drives: 2007 Yaris Liftback White
I've had my 1ZZ TB on for over 20K miles and never had a CEL or oscillation of any kind.
You probably got a defective junkyard TB and swapping out that casing fixed whatever problems you were having with it before.
FunctionSpec is offline   Reply With Quote
Old 03-09-2009, 07:16 AM   #16
that's another possibility, but it would be interesting if you could look at the model number on yours, to test WolfWings' theory!
Old 03-09-2009, 08:12 AM   #17
yarstar
That is it. I bought it from this guy here in Georgia. Really straight up guy and the price was way lower than what I found elsewhere. They get all there parts used off of totaled cars. Back in January when I got mine, he said he had 4 more.
Old 03-09-2009, 02:37 PM   #18
mikenacarato
SIPNDEW
Drives: 15 STI
Originally Posted by gwasabi View Post
no CEL over 100 MPH
lol i didnt mean 100mph, i meant 100 miles of driving
1.8L Engine Swap, Possible? Yaris T-Sport Performance Modifications 4 05-06-2007 06:57 PM
swap for 2zz-ge???? yarisTOONR82 Performance Modifications 12 03-23-2007 07:15 PM
