Old 09-04-2013, 04:57 PM   #1
GTBaker
GTBaker's Avatar
Drives: 2012 Yaris LE
Cruise Control kicking itself out
I was on the highway today doing 110km/hr with CC set. CC all of a sudden kicked out. Thought I hit the stalk with my knee so I quickly flipped the stalk up to re-engage the speed I locked it into. Nothing. Turned off/on CC and set again for 110. A little while later it kicked itself out again and again flipping the stalk upwards it did not want to re-engage.
Has anyone else ever have this happen to them?
GTBaker is offline   Reply With Quote
Old 09-04-2013, 05:04 PM   #2
Do you have an AT or an MT? It could be either the brake switch or clutch switch (if it is an MT) triggering too easily.
Old 09-04-2013, 06:58 PM   #3
GTBaker
GTBaker's Avatar
It's a MT. Could be but why would it wipe out the memory of the last cruise speed?
Old 09-04-2013, 07:14 PM   #4
cwitte
Newbie DIYer
Drives: 2010 Yaris LB MT
I had the same problem with a 2010. There was a loose connection in the (aftermarked but dealer purchased) stalk. Manufacturer defect. It was before I started doing my own work and I made the dealer fix it.
cwitte is offline   Reply With Quote
Old 09-04-2013, 07:26 PM   #5
True. To completely clear the set point it would have to be acting like the on/off switch was pressed.
Do both the CC and SET lights stay on on the cluster when it is in that state?
Old 09-04-2013, 07:32 PM   #6
GTBaker
GTBaker's Avatar
The CC light stays on but I cant re-engage it.
Is there a point when a CC will disengage itself?
Old 09-04-2013, 08:58 PM   #7
The only thing that can cause that is if the vehicle speed drops below the set point by more than 10 MPH. In that case it will disengage and you have to set the speed again.
Old 09-04-2013, 10:03 PM   #8
GTBaker
GTBaker's Avatar
Ahhhh...that's it then. It was climbing a hill. I guess it went too slow. But strangely this hasn't happened before.
Old 09-05-2013, 09:21 PM   #9
Scubaru Steve
Awesome!
Drives: 12 Yaris/07 yaris
mine does that climbing a long hill, the engine is to loaded up and can not keep up. loose 15 kph and cuts out. its normal
its your cars way of telling you to downshift.
Old 09-05-2013, 09:39 PM   #10
Revsson
Maybe CTScott can build a circuit to give the audible command:
"please downshift now"
kinda like when a GPS tells you to turn here.
Rostra 250-1731 cruise control kit for Yaris PeetYaris In Car Entertainment + Electronics (audio / video / alarm) 5 06-26-2011 06:48 PM
Cruise control vs MPG YarisOwnersDad Fuel Economy Forum 15 05-29-2009 03:55 PM
