Old 11-22-2013, 12:50 AM   #1
D-Flo
Former Ford P.O.S. owner
D-Flo's Avatar
Drives: 2012 Yaris SE, automatic, blk
If you're going to buy just one brace, which one?
I've only begun to think about frame stiffening bars, strut tower braces, mid braces, underbraces, etc. and I wonder which one is worth buying if I'm only going to afford one. My goal is slightly improved handling in corners.
Or is it better to invest in larger wheels (mine are 16 inch), or is it better to not buy any braces and save up for a new set of stiffer front end shock absorbers, fuel etc.?
My (uneducated) guess is that the front strut tower braces are the most important.
But maybe longer wheel diameter is the way to go?
D-Flo is offline   Reply With Quote
Old 11-22-2013, 12:53 AM   #2
Whiteline sway bar is the best suspension modification you can make to your car, period.
All other braces are less functional than that main one.
After that, tires! and after that, springs and struts/shocks.
Old 11-22-2013, 01:33 AM   #3
evo165
evo165's Avatar
Drives: peArL yAvItZ!!
Send a message via MSN to evo165
Rear sway bar/brace FTW!! The most effective part that money can buy. :)
1NZ-FE Yaris with JDM RS front & rear bumper | JDM Vitz RS taillamp | JDM Vitz window visors | JDM Vitz Netz logos | JDM leather steering wheel & shift knob | 4k HID | K&N panel filter | Fujitsubo Wagolis exhaust | NST 10% crank pully | KYB Excel-G shocks | NF210 Springs | Cusco 4 points lower arm bar & Type OS top struct bar | RZCrew sub-frame collars | Ultra Racing 19mm rear sway bar & rear lower & center braces | PG Rear 13mm hub spacers | Exzess 2-pot calipers with 282mm rotors | Runstop Rear Disc | SSR Semi-Forge Type F 15" rims | Michelin Pilot Sport 3 195/55/15 tyres
evo165 is offline   Reply With Quote
Old 11-22-2013, 06:19 AM   #4
willygoodness
Drives: 09 yaris hb
+1 on whiteline sway bar
willygoodness is offline   Reply With Quote
Old 11-22-2013, 08:14 AM   #5
BEEF
BEEF's Avatar
Drives: 2008 yaris 3d
I did the sway bar and springs. Body roll all but disappeared. That is what you want.
I also went with the white line.
Old 11-22-2013, 07:39 PM   #6
TOLMACH
Drives: soarer
TRD sway bar
Old 12-03-2013, 04:49 AM   #7
Lars
Yaris beginner
Drives: Yaris XP9F
Only springs? You kept stock shocks?
Cuz I'm thinking about getting those tuv approved Eibach springs that lower the ride 2.5 cms... Along with the rear sway bar and wheel spacers... should be enough work on the suspension for a regular daily commuter, no? :)
Thanks!
Lars is offline   Reply With Quote
Old 12-03-2013, 03:33 PM   #8
Astroman
Modded Moderator
Astroman's Avatar
Rear sway bar. I snagged a TRD and have been very happy.
Old 12-03-2013, 03:55 PM   #9
BEEF
BEEF's Avatar
Yes, I kept the stock shocks. I am down about 1.5" (or 3.81cm)
I did it for the stiffness, not necessarily the low (but it is nice).
Old 12-04-2013, 04:10 AM   #10
Lars
Yaris beginner
Drives: Yaris XP9F
Yes exactly... I wasn't thinking about changing the springs initially... but the nose-up/nose-down movement when accelerating/shifting is really getting on my nerves.
Did changing the springs improve this noticeably for you?
Thanks so much :)
PS: I'm used to a RWD BMW 5-series, which was my daily commuter previously... so maybe I'm extra-sensitive about this behavior.
