![]() ![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris sedan auto / Fit auto Join Date: Oct 2009
Alignment needed when both front struts are replaced?
They're also replacing the drivers side rear shock and would that make for an alignment? I also think they are putting in a new front sway bar and the bushings for the new struts. The Tech looked at the control arm bushings and thinks they are fine so this is why all these things are being done. Hope they are right and the creaking stops. Thanks
2ZR swap. DO IT! Ask how!
The rear really doesn't have any alignment adjustments, unless you get hub shims. The front really should have an alignment done, as there is a fair bit of play in the crash bolts. Not much else to mess up unless you put on drop springs.
Its always good to have an alignment done when u replace front end parts no harm in it i would do both rear too...its recommended to do an alignment every 30k or with new tires ...50 to 80 bucks can save ur tires and plus how ur car drives i do mine after winter cos of the bad roads and stuff one can hit .
I say do it u can only benefit from it . As for ur creaking i find its mainly do to worn out front sway bar links really bad on echos ,yaris are not so bad .When i lowered my car i did new front struts upper bearings and a alignment cos toe gets taken out when u lower left my rear shocks stock for now...just being lazy that will be next. |
All this is under the TOYOTA extended warranty . Should the alignment be included ? They checked alignment before their diagnosis and it's fine . Now it'll be in need for one , never fails .
if they are changing parts over it should be done
![]() ![]() ![]() Drives: 08Yaris2D, 88LandCruiser. Join Date: Jan 2013
Give a man a fish, and he'll eat for a day. Sell a man a fish, and you'll both eat for a day.
Called the service dept. and the alignment is covered by extended warranty .
![]() ![]() ![]() Drives: 2009 yaris 2 door Join Date: Feb 2013
alignment?
Oh Heck Yea Front end alignment is always recommended after front end suspension work.
| lowering spring specs for Yaris | botchilah | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 20 | 03-22-2017 08:47 AM |
| Get your post counts here! *read 1st post for rules* | Astroman | Off-topic / Other Cars / Everything else Discussions | 3414 | 11-04-2012 09:03 AM |
| Non-Yaris Audio install help needed | Revsson | In Car Entertainment + Electronics (audio / video / alarm) | 18 | 08-17-2009 11:47 AM |
| Front Cat Replaced under TSB EG035-06? | TheSilkySmooth | DIY / Maintenance / Service | 20 | 05-31-2009 08:42 PM |
| Front End Alignment after Spring Install? | OK Yaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 12 | 08-26-2006 07:46 PM |
