Old 09-08-2013, 06:43 PM   #1
DINOeggxo
DINOeggxo's Avatar
Drives: white yaris hatchback.
rear beam question: one wheels sticks out more
i don't know if this has been covered or not but:
has anyone else who is super low notice that the rear beam appears to not be even on each side? one wheel seems to stick out 1/4-1/2 inch more on one side than the other.
am i the only one? is there a way to even it out?
DINOeggxo is offline   Reply With Quote
Old 09-08-2013, 07:33 PM   #2
tk-421
tk-421's Avatar
Drives: 5D-07-LB
This seems to be a common issue on the 2nd gen Yaris. I have rear spacers and the passenger one sticks out a bit more (enough to rub the tire against the wheel well).
The only way for me to fix it is by replacing it for a slimmer one, but I've been putting it off for years.
Old 09-08-2013, 09:27 PM   #3
sasquatch
Drives: 04.:R32, 87 Scirocco, 07 yaris
Which car has a slimmer beam that would bolt in?
sasquatch is offline   Reply With Quote
Old 09-09-2013, 01:11 AM   #4
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
I don't think it's fixable. It came from factory this way.
The rear right sticks out about 1/4~1/2" on mine as well.
The only way to make it aesthetically balanced is to put a 3~5mm shim on the left side. Weird, I know.
Old 09-09-2013, 10:45 AM   #5
1.5
Form>Function
1.5's Avatar
Drives: 07 Flint Sedan
I dont notice it on my sedan. Mine look to poke evenly and if anything, my driver side rubs more but i think that is due to weight distribution and seat position. Ive heard this for years with the hatch tho
Old 09-09-2013, 11:06 AM   #6
The body of the car, not the beam is the cause of the liftback. For some odd reason the left side pocket for the beam pivot mount is 13 mm further in than the one on the right side. So, the right side wheel sticks out 13mm further than the left side. Using a 15mm Penguin hub space on just the left side makes them about as close as you can get to even.
Old 09-09-2013, 12:42 PM   #7
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
HAHA! I thought it was my bumper...I feel better now.
-Type 07 FFL-
My odometer 03/11
Old 09-09-2013, 12:53 PM   #8
That much! I always thought it was ~5mm.
I'm running 10mm spacers on both sides with the right side rub driving me nuts when vehicle is semi-weighted down. Guess I should remove right side spacer and be close to equal on both sides then.
Old 09-09-2013, 01:20 PM   #9
We should sell a 5m/10mm Yaris spacer combo.
Old 09-09-2013, 01:39 PM   #10
Mz3oh5
Mz3oh5's Avatar
Drives: 13' HB
How low is your car? 2 inch drop all around??
--- Isabella
Mz3oh5 is offline   Reply With Quote
Old 09-09-2013, 01:59 PM   #11
LOL, I proposed that years ago and you baulked at me
Old 09-09-2013, 02:08 PM   #12
1.5
Form>Function
1.5's Avatar
--- Isabella
being that she is bagged, she is laying frame on the ground, i think its a lot more than 2"
Old 09-09-2013, 02:23 PM   #13
sasquatch
Dang, we were hoping to even it out somehow. Drivers side sits perfect, if only we could bring the pass side in a little!
Old 09-09-2013, 02:23 PM   #14
Mz3oh5
Mz3oh5's Avatar
Drives: 13' HB
WTH!! I plan on dropping mine to a 1.9 all around, but I'm afraid I will regret it later.
--Isabella
Old 09-09-2013, 02:35 PM   #15
jpmck03
jpmck03's Avatar
Drives: 2025 GR86
Old 09-09-2013, 03:29 PM   #16
sasquatch
You won't have a problem unless you're running wide rear wheels that poke it are close to poking. Dinos rear wheels are 15x8.5" with a offset (I think) of +10.
However her car is bagged so she just lifts the rear more so it doesn't rub
Old 09-09-2013, 03:31 PM   #17
1.5
Form>Function
1.5's Avatar
Why would you regret it?
lol its as easy as that huh ^ lol
Old 09-09-2013, 03:38 PM   #18
Flipper_1938
Flipper_1938's Avatar
Drives: 2010 Yaris Sedan
Order a -5mm spacer
Yaris Sport 2009 wheels question andr3w Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 06-05-2013 07:28 PM
hid hi/low. question on using high beam for DRL! marcus Cosmetic Modifications (Exterior/Interior) 22 06-17-2010 03:12 PM
