Old 05-17-2014, 04:59 PM   #1
yaris1F8
yaris1F8's Avatar
Drives: Yaris 1F8
Spark plugs.
Hello guys they told me at the dealer to not touch the plugs before 192 000 kms.. is that possible ? What do you think ?
yaris1F8 is offline   Reply With Quote
Old 05-17-2014, 05:37 PM   #2
IllusionX
Drives: 07 Yaris Sedan Aero
160k km I think from the maintenance schedule. But I changed mines at 120k
Old 05-17-2014, 06:37 PM   #3
The Limo 2
The maintenance schedule says 12 years or 192k km.
Roy
The Limo 2 is offline   Reply With Quote
Old 05-17-2014, 09:22 PM   #4
jack black
jack black's Avatar
Drives: 2007 red Yaris HB AT
Originally Posted by yaris1F8 View Post
is that possible
Yes, with long life iridiums.
This is not your average nickel electrode $1.5 plug.
jack black is offline   Reply With Quote
Old 05-24-2014, 09:26 PM   #5
yaris1F8
yaris1F8's Avatar
Drives: Yaris 1F8
Ok thanks guys.. do you know the torque on the plugs.. how tight do they need to be ? :)
Old 05-24-2014, 11:31 PM   #6
jack black
jack black's Avatar
15 lbs/ft. Less if you use anti-seize.
Old 05-28-2014, 01:32 PM   #7
esse10
Drives: 2009 yaris 2 door
remove
I would remove (50k miles), inspect , check the gap and put back in with anti-seize on the threads for easy removal next time. That's 50,000 us miles. torque? is usually skill of the craft but if you want to be specific it's usually around 20-25 footpounds, and no the value does not change with anti-seize on the threads. 20 foot pounds of pressure is still 20 foot pounds of pressure no matter if the threads have a lubricant on them, it'll slide in a little farther with the lubricant on but not to make a difference, 20 pounds is still 20 pounds. if you had a soft alloy metal that would bend or something I would say yes torque them less if the threads had lubricant, I don't think in this case.
esse10 is offline   Reply With Quote
Old 05-28-2014, 10:59 PM   #8
jack black
jack black's Avatar
Sorry dude, you shouldn't be giving the bad advice like that. Oh, BTW, the head is made from aluminum, it's SOFT metal alright.
Note: If anti-seize compound is used, reduce torque by 30% to avoid over-torquing.
http://mdm.boschwebservices.com/vpf-...park_Plugs.pdf
Old 06-04-2014, 01:55 PM   #9
esse10
dude
dude, you obviously have not take the spark plugs off either. the threaded part in the plug holes is not aluminum threads....dah.
Old 06-09-2014, 11:48 AM   #10
jack black
jack black's Avatar
You're funny, but I'll bite. What is it then, titanium?
Old 06-09-2014, 02:15 PM   #11
Rigaud
Drives: 2009 Yaris
Most aluminum heads are just that, aluminum for the threaded part as well.
Location of Spark Plugs KEVBD DIY / Maintenance / Service 7 02-03-2012 11:05 AM
Laser plugs? - Awesome Altitude Off-topic / Other Cars / Everything else Discussions 1 04-24-2011 08:02 PM
article on spark plugs and the fit kngrsll Performance Modifications 4 08-01-2009 11:50 PM
did autolite spark plugs screw up coil or coils ?? la_scanner DIY / Maintenance / Service 20 04-09-2009 02:07 PM
Upgraded Spark Plugs For Boost whooppee777 Forced Induction Forum 9 02-14-2009 01:53 PM
